Tue, Jan 7, 1:19 AM CST
Forum Moderators: Staff
Subject: V3 with working dials
c567591 ( ) posted Mon, 20 October 2003 at 10:33 AM · edited Tue, 07 January 2025 at 1:14 AM
Is there a way to get V3 to load with certain morphs always loaded & working? The expressions & chest morphs are ones I constantly use. I would love to build a V3 CR2 that will load with the morphs loaded & ready. I would also like this to work after opening a PZ3 w/o having to reload the morphs. Is there a way to do this? I am not afraid of hacking a cr2 or whatever. Thanks. Matt c567591
EnglishBob ( ) posted Tue, 21 October 2003 at 4:05 AM
  1. Inject the morphs you want into a blank Vicki. 2) Save her to the Character library. 3) There is no third thing. :)
c567591 ( ) posted Tue, 21 October 2003 at 9:11 AM
I did that, and I have the dials, but they don't do anything until I reinject the appropriate morphs. Usually the "All expressions", when I do that, then they work.
EnglishBob ( ) posted Tue, 21 October 2003 at 3:48 PM
Ooer... weird. All I can say is, it works for me as described; which is the way it's supposed to work, whether from a CR2 in the library or a saved PZ3 document. You might try cross-posting in the main Poser forum in case someone else has had the same trouble, since this one doesn't get as much traffic. Don't forget to tell them what version of Poser you have. I believe there may be compatibility problems with Poser 5 (I have 4.03).
pizzone ( ) posted Wed, 22 October 2003 at 6:26 AM
The problem could be the position of the folder "!DAZ" (which contains all of the INJ and REM morphs for V3)in your Poser directory. I don't know if You use Pbooost or other programs to manage your Poser libraries, but the folder "!DAZ" MUST ALWAYS be in Poser/Runtime/Libraries and You never have to change its location (e.g.:swapping it with other folders); otherwise the .cr2 or the .pz3 You created will not find the morphs and they won'y work. I hope it helps. Alberto
c567591 ( ) posted Wed, 22 October 2003 at 8:50 AM
Hmmm... Perhaps that is what I did. :( Bummer.
