Yes as said SAMS3D and wabe you do just that and then put some general thermal erosion on it (you terrain should at least be 512 x 512 ) Then maybe, you'll have to reduce the Z dimension of the terrain once imported in the scene...(I should have used the term 'elevation map' instead of Bumpmap pardon me ) Hope you manage cause I am impatient to see your pict.
Attached Link: http://http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=1488717
I am trying to put polax's ripple bump map onto a terrain. I can't seem to find how to load the bump map in. The ripple is on this thread.
