Wow! Not what I expected :) Really good pic. I think he would be a calender man of Samurai Weekly. :) Three things - if there are lights on both sides of the hallway? road? try putting a darker blue kicker light to his front and right (our left) that should add some definition to his hand, which is dissapearing. Also the upper blade might look better if turned slightly so it is not edge on to the viewer. Its hard to view it as a sword at first. And lastly, I hope after all he's been through he should have at least some blood on his blade. Keep up the good work :)
ok, Yes Itook your advice and put the new vertion on in the galery, though I chose to keep the blades Kleen, because since it is now "His turn", he hasen't used them yet... I know it sounds bad, but I decided to use that to add tention to the image. I though it made him look more menusing. I also changed his snear to a smerk in the new one for the same reason. check it out in the galery. -Gabe-
Content Advisory! This message contains violence
Attached Link: DreamScape Graph-x Co.
![file_131314.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_131314.jpg)
Ok, I have been working on blood, scars, (which as I have found are hard to do) and for and lighting. what do you think. -Gabe-
