Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
I'm not as dumb as I look :-). - Found out that Poser5 allows to set a coordinate scaling in preferences. This was in inches by default and I changed it to Poser internal. Now this is OK. - Regarding the thumbs it seems that Poser5 can not handle the format Photoshop7 is doing by default. Didn't find out what option to chose so that it works :(. Any idea?
Attached Link: Poser thumbnails
See the attached link for how to fix Poser thumbnails. It's a tutorial on how to make your own thumbnails, but it also tells you how to fix them if they're not working. You need a free program called P3d0 Explorer. It's very easy. Basically, you use P3d0 Explorer to convert the existing thumbnails to the format your version of Poser can use.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Just got Poser5 for PC last week and wanted to use a prop that worked fine with P4. 2 proplems occured: - I have *.png files for all props, but I don't see the thumbs in Poser5. Resaved them with Photoshop7. It didn't help :( - This prop is a construction set. The floor consists of tiles and they create a perfect plane by loading the prop several times and moving them in x- or z-direction. Somehow it seems they changed the scale of the coordinate system from P4 to P5. Is this the case or am I doing something wrong? Please help me before I become completely desperate. Thanks - Walter
