Wed, Dec 4, 7:08 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
Subject: Poser Won't Render?
indigoskye ( ) posted Sat, 25 October 2003 at 9:20 PM ยท edited Tue, 03 December 2024 at 6:44 PM
Hi there. I am working on a project and suddenly my Poser 4 is refusing to render! I get the message, "Insufficent disk space to render at this resolution". Well, I am not rendering anything different than I've done hundreds of times before and when I tested at lower resolutions, I got the same message. Compared to most people, I don't do "huge" renders. Would anyone know of a quick fix for this? I'm working on a deadline and need my program to work ASAP. Thanks!
akura_ ( ) posted Sat, 25 October 2003 at 9:43 PM
your background memory of your pc has just run out, try rebooting. its happens when you use poser to long or leave alone without useing it. if that doesn't work change the resolution to your monitor. hope this helps:)
EnglishBob ( ) posted Sun, 26 October 2003 at 9:42 AM
Also check the FAQ at Curious Labs' site. If rebooting doesn't fix it, there are changes you can make to your virtual memory settings - the procedure varies according to your Windows version.
