Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 9:52 am)
In UVMapper use the Tools/Weld vertices function. If that was the error you should receive a notice saying that so many vertices are now welded. Re-save your OBJ and try the Poser figure again. Also check your grouping. It wouldn't be the first time I have mixed up my rights and lefts and labeled the right collar lCollar. The results are similar to what you see.
To cure the shading select your lights and turn up the map size to 1000.
To me it looks like the weld statement for that seam is missing. Look at the end of the cr2 and see if there is a weld statement attaching those two parts.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
![file_81588.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_81588.jpg)
Hi,Can anyone see what I do wrong?
The model is sliced in UV mapper Pro. Is there something I do wrong there maybe.
I have used P-wizard to make the cr2 from a cr2 Don inside Poser 4 (note, I have license on P5).
What are these shades?
Thanks,
Snekkis
