Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
Attached Link: http://www.philc.net
Try the cloth room. There are tutorials by PhilC that show how to do this. There are others, can't remember the urls. I'm sure others will know.How much smaller? I have a character with effectively no breasts at all, and I spend more time creating flat-chested morphs for her clothing than I do rendering her.
If you have naoki's tank top or the Project Lara XShirt (available at 3-D Arena and other sites), I can send you my morphs for those items.
Hi there... Thanks to you both!! Little Dragon, when I tried to download naoki's tank top, it says that the file was corrupted. I tried on two different computers. The second one on the page, the "recqueen" one downloaded fine... and although it looks like the breast size I wanted, when I tried it on my model, again it was a little big, and it wrinkled when I tried to make it smaller. And I did try using Tailor. I will keep trying... I am using aiko Model with the following morph dials: .500 Breast Gone I compare it to about a "B" cup in real life, versus the "D" plus cup that is the default. If I used your morphs, would I be able to increase the size? I'm sorry... I just don't know that much about the morphs. Thanks again!!
Is that your model in the picture? Mine definitely would be a larger size than that one. But I would still appreciate seeing your morph targets if you could send them to me. I could probably learn by your example. I've emailed naoki and asked if they would send the tank to me... so, I guess we'll see. Thanks again, SKCgirl
Since you downloaded the RaceQueen outfit successfully, I made a similar set of morphs for it. Here's how it looks at a value of 1.0.
(Please excuse the neon-green colour of the dressmaker's dummy; I use that to check for poke-through.)
Let me know where to mail these.
skcgirl.Try the DL for the tank top/cut offs again...I just got them and they work fine(thanks LD). Sometimes a site will get hicups and give you corrupted files. You might want to look for tops and dresses that are made for the Preteen Vic(MilliGirls)...you'll have to do some dial turning,but I've gotten good results...(don't try pants or tight fitting clothes). SWAMP
Hi again... Little Dragon, I sent you my email address to send the morphs to...
Carolly... I will definitely check out Geralday's site... I had seen his "creme" before, but thought it was just a prop for a beauty scene :}
And thanks for the heads up, SWAMP... the site was working again, as well as naoki was generous enough to email me the zip files... I will definitely check out the pre-teen stuff... how sad that a realistically curvy model like the one I have is associated with a "pre-teen." Oh well.
Thanks to everyone again... you have definitely helped!!
The morphs for both items are on their way, skcgirl. Incidentally, I have The Tailor, also, but I haven't much practice with it yet and experienced the same "wrinkle" problem with smaller breasts. These morphs were created primarily with Poser's magnets, and some additional tweaking with a 3D modeling application.
Just letting anyone know... I found that the following tank top... We added morph targets through Tailor and it did not wrinkle to adapt with the smaller breasts. It is currently in the "freestuff" section and is called: " 072002 : Clothing for Vicky " and is made by: wusamah It was posted on July 21, 2002. (sorry, I don't know how to attach a link) This is a very well made item. Catch ya all later!! SKCgirl
Hi there. I am currently using Poser 5 and I have a character with smaller breasts... and I am trying to find a tank top for her, but everytime I find clothing, the fabric gets "wrinkled" when I try and fit it to her smaller breasts. Does anyone have any ideas or models? I could also use a dress with a similar top, but I haven't found one that works yet... I was told I should look for something "morphable."
BTW... The character is based on the Vicki/Stephanie.
I looked at past posting where the collar dial, etc. were suggested, but it doesn't seem to do it. Any help would be greatly appreciated.
Thanks and have a great weekend!!
