Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 24 5:00 pm)
Elegant Interiors - The Bedroom is a spacious and elegant modern bedroom interior complete with beautifully detailed furnishings and fixtures. The Bedroom comes with everything you need to create stunning bedroom renders.
The Bedroom features many beautiful and unique areas for scene creation and makes scene creation easy by using separate props for the front wall & ceiling. 12 Camera presets are included to cover every view on the room. Two light presets are all that is needed to light the front or rear areas as desired.
The Bedroom also features a stunning large skylight that can be captured with many standard camera views of the room. The Bedroom also includes a usable closet that can be accessed by opening the closet doors.
Elegant Interiors - The Bedroom comes with the following 20 furniture and room props in PP2 format:
Everything comes as Poser Ready props that can be loaded from the sidebar menu or for even easier use - just load the included PZ3 file which has all of the props loaded with a default lighting and camera scheme.
All of the prop's elements are completely modular and can be used separately or with other sets for maximum use and enjoyment.
Elegant Interiors - The Bedroom set comes with high resolution textures that look great from a distance or at extreme close up renders.
Available now at the Renderosity Marketplace for only $9.95!
