Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1102480
I had that problem too and I sought for help from the older messages. I found that it can't be done easily directly. Instead, you can save the goose into another file with the animation and no other objects in it. Then import it back to the original file. It is a bit complicated but this way the mesh and the skeleton get grouped(which you cannot do by hand either) and then you can change the position for the other geese. Maybe someone else has newer information and better ideas but I couldn't figure out any. At least it worked this way for me. I've attached a link to the old messages for you to check for yourself if you want to. -HKThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Never Give Up!
