Fri, Jan 24, 1:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Subject: Devil's Spawn - getting faces from the face room!
elgyfu ( ) posted Thu, 06 November 2003 at 1:35 PM ยท edited Fri, 24 January 2025 at 1:02 PM
It seems so easy in principle. All I want to do is be able to save my faceroom faces so that I can load them onto Judy another time - and offer them to you guys! There is a button marked 'Spawn morph' but I can't figure out what it does! The Poser 5 manual just announces that it 'spawns morphs'. Well, duh! So where are these spawns? What on earth do you do with them when you find them? Any help, please!
xantor ( ) posted Thu, 06 November 2003 at 4:07 PM
If you bring up the parameter dials for the head, the spawned morph appears in the morph category and it is called head. If the dial is at zero set it to one to change the head shape. You should be able to save it as a morph target the usual way. File/export/wavefront object single frame and save only the head no eyes or any other parts. If you make a new scene you can load your character and test the morph. In the object menu do load morph target after selecting the head. You may have to adjust the position of the eyes. I hope this helps...
elgyfu ( ) posted Fri, 07 November 2003 at 1:56 AM
Thank's very much Xantor. I wonder why Curious Labs didn't just say that in the manual! Now to play......
marco-xxx ( ) posted Fri, 07 November 2003 at 4:11 AM
When you hit "spawns morph" Poser creates non only a morph for head but also two morphs for eyes, so you need export also the eyes morphs
