Sat, Jan 25, 7:26 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 6:57 pm)
Subject: Why the texture reflection
DarkEden ( ) posted Thu, 10 August 2000 at 9:24 AM ยท edited Sat, 11 January 2025 at 4:23 PM
I have a problem as you see. I use a transparan map as you can se on the stomache and on the breasts but! why doesn't it get Transparant on the stomache as on the breasts? When i set the light it can go away but nope it still cast a refection... whats wrong??? The cloth i'm using is a Futuresuit made by J.Chavez
DarkEden ( ) posted Thu, 10 August 2000 at 9:29 AM
Oh yeah the blue and green stuff is just for marking the area that i meen.... DE
Ghostofmacbeth ( ) posted Thu, 10 August 2000 at 12:05 PM
Normally it means that there wasn't a pure color or black or white there ...Black would be transparant but it it was only 90 something percent grey it would look like that.
cooler ( ) posted Thu, 10 August 2000 at 12:39 PM
Make sure your transparency falloff slider is set to 0%. Otherwise poser will try to "blend" the falloff zone into the surrounding areas & you'll won't get full transparency
