Sat, Jan 11, 9:47 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Spawning Morphs ala Python
Traveler ( ) posted Sat, 08 November 2003 at 6:55 AM · edited Wed, 24 July 2024 at 5:21 AM
Would it be possible through Python to spawn morphs across the figures body if magnets are applied and/or morphs are set above 0? So it would look at each body part, if a magnet is applied or morph used, spawn a morph with a name you could type in? Maybe even set up the FBM dial too? This is one of the more time consuming parts of doing Full body morphs with magnets :(
ockham ( ) posted Sat, 08 November 2003 at 11:09 AM
Sure. I haven't used the FBM, but I know the rest is possible. Will try out the FBM ...... results coming shortly.
My python page
My ShareCG freebies
amberf ( ) posted Wed, 12 November 2003 at 4:35 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12390&Form.ShowMessage=1495455
Stewer wrote one but it doesn't have an interface to type in the morph name. It will spawn the morph target for all the body parts regardless of whether or not there are magnets affecting the body part but it doesn't seem to create the FBM. There's also a script that will set all the morph targets to 1 but again, no interface to specify which morph targets to set to 1. Ockham, if you can get the FBM to work and put an interface on it so we can type in the morph name that would be awesome!
PhilC ( ) posted Sat, 15 November 2003 at 5:16 PM
I got the spawn morph targets to work but not the set values to 1.000 script. I got round the input name by just having the python file open in notepad and editing the morph name each time. That and the delete magnet script saved a bunch of time. If you can get this to work it will indeed be awsome.
