Mon, Dec 2, 2:39 PM CST
Subject: help with injections.
pyrebeast ( ) posted Fri, 14 November 2003 at 5:49 PM ยท edited Sat, 10 August 2024 at 4:33 AM
i have a problem. i cant seem to get the inj. to work on v3, m3, or freak. the only one that seems to be working is the mike jr. inj from the freestuff!!!!! i dont know what to do cuz i think ive tried everything.
pyrebeast ( ) posted Fri, 14 November 2003 at 5:51 PM
also which color do you like,,,, the black one as seen above,,, or this one
or this one
or this one
pyrebeast ( ) posted Fri, 14 November 2003 at 5:52 PM
or this one,,,,please post thanks
PapaBlueMarlin ( ) posted Fri, 14 November 2003 at 6:48 PM
OK...first, do you have the injection morph packs from DAZ. They came separate from the figures themselves. Second, do you have all of the updates? Third, are you using Poser 4 or Poser 5? There's a big difference involved with the last one...
RHaseltine ( ) posted Sat, 15 November 2003 at 6:09 AM
Is the figure you are trying to inject the very first one loaded into a new, empty scene?
ronstuff ( ) posted Sat, 15 November 2003 at 1:14 PM
I can't help with the injections, but I like all your color combos :-) and the whole figure as well - very nice job. My Favorite is #4 followed by #5 - but they are all pretty nice.
pyrebeast ( ) posted Sat, 15 November 2003 at 3:12 PM
i am using poser 4. is that not a good thing? sho;uld i go to poser 5? and why does it make a diff? i have the body and head morphs but lik e i said they dont work. the only ones that work.. after constant freezing of my computer are the barbarian m3 morphs, the mike jr inj from freestuff, and another thing that is in the free stuff. ican remember what it was.
RHaseltine ( ) posted Sun, 16 November 2003 at 6:37 AM
The different versions of Poser have some different bugs, but injection should work with all of them (actually P5 requires marginally more setting up, as you have to put the folder with the injectable data in the right Runtime). Create a new scene (Cmd/Ctrl-n). Is it empty? If not, delete any figures and either set that as your prefered state (page 26 of manual) and do a new scene again or just save the empty scene, close it and then reopen it. Load M3 from the Figure library (if you've only just bought it you should have all the updates pre-applied, if it's older go to DAZ and get the updaters for the base figure and body morphs, though injection worked fine on the pre-updated version). Go to the Pose library, choose the !M3 Full-Body INJ folder, double click on Muscular1. Select M3's body - has a dial appeared at the top of the stack of parameters? If not try selecting a body part, then go back to the Body. If nothing is there you have a bad download or install, if the dial is there just turn it, or type in a value, to apply whatever degree of the morph you want.
pyrebeast ( ) posted Sat, 22 November 2003 at 3:25 AM
thanks
