Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Yes you can use Possette poses on Vicky. But bear in mind that Vicky has a few joints that Possette lacks. Key things to do: add up the values in the neck and head and then re-average them out. Possette only had a neck and head. Vicky has a lower neck, upper neck, and head. Likewise for buttocks which are a new item between the hip and thigh and collar which is new between chest and 'shoulder' (which for vicky is just the upper arm now). So You can apply them but it takes some work. The first thing you should do is take your model in a zeroed out pose. (That is a restore-figure then put all morphs back in. Easy to do by doing restore figure, then loading in a new copy of your morphed vicky over the restored one so that she assumed the base pose.) Take her in that pose and save a pose dot with it. Then everytime you switch poses with Vicky using a pose that wasn't made for her apply the pose dot first. Otherwise some elements will not reset when she changes pose. There are losts of poses out there for her though. Mostly here. Do a search through this forum for vicky , victoria, and millie. It may take quite a few hours but you'll find them.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
Just bought vickie from zygote, looking for poses, didnt see any on free stuff. Does anyone know of any ?
