Fri, Jan 10, 12:55 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Load an external program from Python?
layingback ( ) posted Sat, 15 November 2003 at 2:23 PM · edited Thu, 09 January 2025 at 5:21 PM
New to Python, so perhaps one of the experts here can point me to a command in Poser Python to load an external (Windows OS) task? Poked around a bit, but not been able to track down the method. Thx.
stewer ( ) posted Sun, 16 November 2003 at 10:14 AM
Attached Link: http://www.python.org/doc/2.2/lib/os-process.html
You can use os.spawnv() to launch an external application in a separate thread, os.execv() to run the command in the same thread (making your script an Poser wait until the command finishes). You can read details about it in the Python documentation, see the link.
