Fri, Dec 27, 4:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Jerky motion when applying walk designer to a figure with a path. . .
LazloHollyfeld ( ) posted Mon, 17 November 2003 at 10:35 PM ยท edited Fri, 27 December 2024 at 4:15 AM
Hi Everybody! I'd like for my figure to run on a path I created for him. I go into the walk designer, then set the slider for Run to the right amount. The preview animation seems fine, and I click apply. When I playback the figure in the real window, the figures legs jerky around. It's as if the legs are snapping back to a position. If I have the runner, "walk in place" and repeat the cycle, then the runner does the motion just fine. Am I missing something? Why does the jerkyness happen when I apply it to a path and not a "walk-in-place"? Thanks for all your time and help. If you've encountered this before, please let me know. Any feedback would be appreciated! Thanks!!
xantor ( ) posted Tue, 18 November 2003 at 1:11 AM
This is a small bug in poser. There is a Python script somewhere that fixes it. You can go to each individual frame and fix the legs this is a pain but it works...
rykerssc ( ) posted Tue, 18 November 2003 at 3:59 AM
hi, is it poser 5 ? when it is, install the latest update. than it works. i had this probs too. and after the update, the walkdesigner will work fine.
LazloHollyfeld ( ) posted Tue, 18 November 2003 at 8:00 AM
Thank you both for your help! I updated my Poser5 package and everything is fine. I appreciate your time and help.
