Attached Link: http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=1526367
Yes, you can do a serial of images in applying every x second a new material (can be a bitmap) to your object. If you have the courage and plenty of time to do so:-) For animated material see the link above.If I not missunderstand you, you mean that I have to manually change the image for every image frame to render as the animation inside Vue as well as the Vue animation itself is at 25fps. If so the answer to my question is not Yes but rather No! ;) I suppose that if Vue 4 Pro was in a working condition I could use python script in order to change the images but untill it's fixed I'm stuck with Vue 4.
Say you want to do a render of a camera panning a city with big animated advertices (as in Blade runner). This means that I have to be able to apply a movie file or serial of images onto an object. Is this possible?
