Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Hey any answer if fine with me, let me know if you are successufull or not. I plan on doing it to but am cought up a huge project for school and will be a week or so befor I can get to it. The bigest question I have is about the Freaks joint paramiter. If they are really different I haven't figured out how to set a pose file that changes though yet.
I'm working on transfering a Freak-shaped morph to the Pirate clothing right now (I wasn't going to work on this yet but I wanna know). I don't know about the JP's, I don't even have a clue how to set them up. I'm going to see if the item conforms correctly or not and may or may not (depending on result) run it through P-Wizard to see how that works. I'll post back in a little while with my results.
Presenting, Mr. F wearing M3's Pirate Clothing.
For the most part, simple transfer of morphs, then loaded/conformed to the Freak and turned the clothing's new dial to "Freak"... Some pokethru issues that are solved by the usual curative measures (scaling, invisibility).... NO postwork, no morphs on the Freak except M3's expressions and whatever the little guy comes preloaded with.
All in all, it works, at least for the Pirate clothing.
Ok, I'm going to work now.
Well, I would imagine that there wouldn't be any problems converting to Freak from M2 than if you went M3 from M2. Ookami, yep, via Tailor... Using the tut at Daz Tutorial Arcana, created an M3 mannequin prop with a "Freak" shaped morph and used it to put a "Freak" morph into the Pirate pak. From this test, it appears that ole Mr. F and M3 share JP's, or are very similar. Oh, wouldn't it be wonderful if someone with the knowhow would create a JP Pose for the Freak to truly get his clothes to fit just right?
I would think that is you used the steph obj as a morph tatget with the vic 3 as the body saved as a pp2 you would be able to get the right body shape to vic 3 clothes in the tailor but steph is also a different size so I guess you might have to play with scaleing as well. this is all hawever conjecture as I haven't had a chance to try it yet.
Attached Link: http://arcana.daz3d.com/index.php?id=128
Oh, sure. Follow my M2 to M3 tutorial, but instead of M2 load the V3 object, and instead of M3, load the Steph 3 object as the morph target. It really is saved as a pp2. You can force the Tailor to show props by typing "*.pp2" into the open dialog box. However, I'm not sure if this works in older versions of Tailor. Version 1.5 does fine, but earlier versions have been known to error out. 'Fraid I haven't made a Steph 3 joint setting pose yet, though.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Has anybody attempted to convert M3 clothing to the Freak using the Maniquin and the Tailor??
