Mon, Jan 27, 6:23 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Spline Modeller Problem
ahookey ( ) posted Mon, 24 November 2003 at 9:18 AM · edited Mon, 27 January 2025 at 4:31 PM
Hello, Having a problem in the spline modeller. I'm trying to extrude a circle along a spline to create a cable loop. See image. The view shown is a view from the left. As you can see the extrusion does not follow the spline, one is offset. The extrusion method = pipeline, extrusion envelope = none. I'm using C3, but I had the same problem in C2. Anyone know how to solve this? Thanks, Andrew
MarkBremmer ( ) posted Mon, 24 November 2003 at 9:40 AM
In the Spline Room with the first cross section selected, choose the Sections pull-down menu, choose the Center option which will center the cross section and fix the problem.
ahookey ( ) posted Mon, 24 November 2003 at 12:58 PM
Hoooraahhh! Such a simple solution! It's interesting 'cos I always centre the cross section first before I start the path. Thanks Mark.
