Sat, Jan 25, 2:45 AM CST
Subject: Tutorial clothes for any mike to fit M2, M3, The Freak.
nightfir ( ) posted Fri, 28 November 2003 at 12:41 PM · edited Sun, 19 January 2025 at 12:06 AM
Here's a little something I put together the day before Thanksgiving.
Clothes to fit mulitple poser characters by nightfir (Brad Hall).
Want to have clothes that fit Mike 2 fit on Mike 3?
Want to have clothes that fit Mike 2 fit on The Freak?
Want to have clothes that fit Mike 2 fit on both Mike 3, and The Freak?
Want to have clothes that fit Mike 3 fit on Mike 2?
Want to have clothes that fit Mike 3 fit on The Freak?
Want to have clothes that fit Mike 3 fit on Mike 2, and The Freak?
Want to have clothes that fit The Freak fit on Mike 2?
Want to have clothes that fit The Freak fit on Mike 3?
Want to have clothes that fir The Freak fit on Mike 2, and Mike 3?
Want to have a Mike 3 figure with all his body morphs applied?
Want to have a Mike 3 figure with all of The Freak's body morphs applied?
Want to have a Mike 3 figure with all of his, and The Freak's body morphs applied?
Want to have a The Freak figure with all his body morphs applied?
Want to have a The Freak figure with all of Mike 3's body morphs applied?
Want to have a The Freak figure with all of his, and Mike 3's body morphs applied?
This tutorial shows how to make.
PROP FIGURES
M2 to M3.pp2
M2 to M3 to The Freak.pp2
M2 to The Freak.pp2
M3 to M2.pp2
M3 to M2 to The Freak.pp2
M3 to The Freak.pp2
The Freak to M2.pp2
The Freak to M2 to M3.pp2
The Freak to M3.pp2
CHARACTER FIGURES
M2 to M3.cr2
M2 to M3 to The Freak.cr2
M2 to The Freak.cr2
M3 to M2.cr2
M3 to M2 to The Freak.cr2
M3 to The Freak.cr2
The Freak to M2.cr2
The Freak to M2 to M3.cr2
The Freak to M3.cr2
MORPH TRANSFER FIGURES
Mike 3 with all of his body morphs applied.
Mike 3 with all of The Freak's body morphs applied.
Mike 3 with all of his, and The Freak's body morphs applied.
The Freak with all of his body morphs applied.
The Freak with all of Mike 3's body morphs applied.
The Freak with all his body morphs, and Mike 3's body morphs applied.
The morph transfer figures are so you can apply selected morphs to clothing items, and, or
the character figures created above.
The character figures are for the new clothing items you are changing.
The prop figures are so you can transfer morph targets to your clothing item you are changing,
and the new character figures you are creating.
STUFF NEEDED:
Mike 2.
Mike 3. I used Mike 3 SR1.
Mike 3's body, and head morphs.
The Freak.
The Freak's body, and head morphs.
Poser. I used Poser 5 with SR3.
The Tailor 1.5 RC1.
NOTE: You do not have to close Poser, or The Tailor after each step below if your going to sit
down, and do everything in one shot. I just put that in so you can stop, and pick up later
if you don't have enough time to do this all in one shot. I did all this in a 10 hour session
more, or less. This all takes a great deal of time. I was using a computer with a 1.7 GHZ
Intel Celeron, and 512 megs installed. So you may get better, or worse results depending on
the computer setup you have.
CREATE NEW FOLDERS.
Open Windows Explorer.
Goto Poser 5/Runtime/Libraries/Character/.
Create a new folder called Mannequin.
Goto Poser 5/Runtime/Libraries/Props/.
Close Windows Explorer.
CREATE A M2 TO M3 PROP.
Open Poser 5.
Clear Poser 5 of any default figures loaded.
Click on file in Poser 5's main menu.
Click on import in the file menu.
Click on wavefront obj in the import menu.
Load blMilMan_M3_m2.obj in the wavefront obj window.
Click on open in the wavefront obj window.
Unselect all prop import options in the prop import options window.
Click on ok in the prop import options window.
Click on options in Poser 5's main menu.
Click on load morph target in the options menu.
Change shape 1 to M3 in the apply target dialog window.
Click on locate in the apply target dialog window.
Load blMilMan_m3.obj in the open window.
Click on open in the open window.
Click on ok in the apply target dialog window.
Save the prop in the props mannequin folder as M2 to M3.
Close Poser 5.
CREATE A M2 TO M3 TO THE FREAK PROP.
Open Poser 5.
Change shape 1 to The Freak in the apply target dialog window.
Load blFREAK.obj in the open window.
Save the prop in the props mannequin folder as M2 to M3 to The Freak.
Close Poser 5.
CREATE A M2 TO THE FREAK PROP.
Open Poser 5.
Save the prop in the props mannequin folder as M2 to The Freak.
Close Poser 5.
CREATE A M3 TO M2 PROP.
Open Poser 5.
CLick on wavefront obj in the import menu.
Load blMilMan_m3.obj in the wavefront obj window.
Change shape 1 to M2 in the apply target dialog window.
Load blMilMan_M3_M2.obj in the open window.
Save the prop in the props mannequin folder as M3 to M2.
Close Poser 5.
CREATE A M3 TO M2 TO THE FREAK PROP.
Open Poser 5.
Save the prop in the props mannequin folder as M3 to M2 to The Freak.
Close Poser 5.
CREATE A M3 TO THE FREAK PROP.
Open Poser 5.
Save the prop in the props mannequin folder as M3 to The Freak.
Close Poser 5.
CREATE A THE FREAK TO M2 PROP.
Open Poser 5.
Load blFREAK.obj in the wavefront obj window.
Save the prop in the props mannequin folder as The Freak to M2.
Close Poser 5.
CREATE A THE FREAK TO M2 TO M3 PROP.
Open Poser 5.
Save the prop in the props mannequin folder as The Freak to M2 to M3.
Close Poser 5.
CREATE A THE FREAK TO M3 PROP.
Open Poser 5.
Clear Poser 5 of any default figues loaded.
Save the prop in the props mannequin folder as The Freak to M3.
Close Poser 5.
CREATE A M3 MORPH TRANSFER FIGURE WITH ALL OF M3'S BODY MORPHS.
Open Poser 5.
Clear Poser 5 of any defualt figures loaded.
Load M3 BLANK SR1 with out any morphs applied.
Apply all M3 body morphs to M3 BLANK SR1.
Save as M3 M3BM in the figures mannequin folder.
Close Poser 5.
CREATE A THE FREAK MORPH TRANSFER FIGURE WITH ALL OF THE FREAK'S BODY MORPHS.
Open Poser 5.
Load !The FREAK BLANK with out any morphs applied.
Apply all The Freak body morphs to !The FREAK BLANK.
Save as The Freak TFBM in the figures mannequin folder.
Close Poser 5.
nightfir ( ) posted Fri, 28 November 2003 at 12:42 PM
CREATE A M3 MORPH TRANSFER FIGURE WITH ALL OF THE FREAKS'S BODY MORPHS. Open The Tailor 1.5 Click on file in The Tailor 1.5's main menu. Click on load the base figure in the file menu. Load The Freak TFBM. Click on file in The Tailor 1.5 main menu. Click on load the dress in the file menu. Load as the dress figure M3 BLANK SR1. Click on morphs in The Tailor 1.5 main menu. Click on body - add all fbm in queue. Click on create morphs in The Tailor 1.5 main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in The Tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M3 TFBM in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE A M3 MORPH TRANSFER FIGURE WITH ALL OF M3'S BODY MORPHS, AND THE FREAKS BODY MORPHS. Open The Tailor 1.5 Click on file in The Tailor 1.5's main menu. Click on load the base figure in the file menu. Load M3 M3BM. Click on file in The Tailor 1.5 main menu. Click on load the dress in the file menu. Load as the dress figure M3 TFBM. Click on morphs in The Tailor 1.5 main menu. Click on body - add all fbm in queue. Click on create morphs in The Tailor 1.5 main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in The Tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M3 M3TFBM in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE A THE FREAK MORPH TRANSFER FIGURE WITH ALL OF M3'S BODY MORPHS. Open The Tailor 1.5 Click on file in The Tailor 1.5's main menu. Click on load the base figure in the file menu. Load M3 M3BM. Click on file in The Tailor 1.5 main menu. Click on load the dress in the file menu. Load as the dress figure !THE FREAK BLANK. Click on morphs in The Tailor 1.5 main menu. Click on body - add all fbm in queue. Click on create morphs in The Tailor 1.5 main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in The Tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter The Freak M3BM in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE A THE FREAK MORPH TRANSFER FIGURE WITH ALL OF THE FREAK'S BODY MORPHS, AND M3'S BODY MORPHS. Open The Tailor 1.5 Click on file in The Tailor 1.5's main menu. Click on load the base figure in the file menu. Load The Freak TFBM. Click on file in The Tailor 1.5 main menu. Click on load the dress in the file menu. Load as the dress figure The Freak M3BM. Click on morphs in The Tailor 1.5 main menu. Click on body - add all fbm in queue. Click on create morphs in The Tailor 1.5 main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in The Tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter The Freak TFM3BM in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE THE FREAK TO M2 TO M3 FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load The Freak to M2 to M3.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/Mannequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load !The FREAK BLANK in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blFREAK.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand The Freak to M2 to M3 in the left hand window of The Tailor 1.5 to show the following: blFREAK blFREAK Groups default Materials Morph targets M2 M3 Select M2. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter M2 in the create a new body morph window. Click on ok in the create a new body morph window. Unexpand The Freak in the left hand window of The Tailor 1.5. Expand The Freak to M2 to M3 in the left hand window of The Tailor 1.5 to show the following: blFREAK blFREAK Groups default Materials Morph targets M2 M3 Unselect M2 in the left hand window of The Tailor 1.5. Select M3 in the left hand window of The Tailor 1.5. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. If all ready selected skip the next step. Click on create morphs in The Tailors 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter M3 in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter The Freak to M2 to M3 in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE THE FREAK TO M3 FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load The Freak to M3.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/Mannequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load !The FREAK BLANK in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blFREAK.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand The Freak to M3 in the left hand window of The Tailor 1.5 to show the following: blFREAK blFREAK Groups default Materials Morph targets M3 Select M3. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter M3 in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter The Freak to M3 in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE THE FREAK TO M2 FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load The Freak to M2.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/Mannequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load !The FREAK BLANK in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blFREAK.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand The Freak to M2 in the left hand window of The Tailor 1.5 to show the following: blFREAK blFREAK Groups default Materials Morph targets M2 Select M2. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter M2 in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter The Freak to M2 in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE M3 TO M2 TO THE FREAK FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load M3 to M2 to The Freak.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/Mannequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load M3 BLANK SR1 in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan_m3.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand M3 to M2 to The Freak in the left hand window of The Tailor 1.5 to show the following: blMilMan_m3 blMilMan_m3 Groups default Materials Morph targets M2 The Freak Select M2. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Unexpand M3 in the left hand window of The Tailor 1.5. Expand M3 to M2 to The Freak in the left hand window of The Tailor 1.5 to show the following: blMilMan_m3 blMilMan_m3 Groups default Materials Morph targets M2 The Freak Unselect M2 in the left hand window of The Tailor 1.5. Select The Freak in the left hand window of The Tailor 1.5. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. If all ready selected skip the next step. Click on create morphs in The Tailors 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter The Freak in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M3 to M2 to The Freak in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. Create M3 to M2 FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load M3 to M2.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/ annequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load M3 BLANK SR1 in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan_m3.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand M3 to M2 in the left hand window of The Tailor 1.5 to show the following: blMilMan_m3 blMilMan_m3 Groups default Materials Morph targets M2 Select M2. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter M2 in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M3 to M2 in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE M3 TO THE FREAK FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Click on load the dress in the file menu. Expand M3 to The Freak in the left hand window of The Tailor 1.5 to show the following: blMilMan_m3 blMilMan_m3 Groups default Materials Morph targets The Freak Select The Freak. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter The Freak in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M3 to The Freak in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE M2 TO M3 TO THE FREAK FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load M2 to M3 to The Freak.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/Mannequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load Michael 2 in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan_hip.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand M2 to M3 to The Freak in the left hand window of The Tailor 1.5 to show the following: blMilMan_M3_M2 blMilMan_M3_M2 Groups default Materials Morph targets M3 The Freak Select M3. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter M3 in the create a new body morph window. Click on ok in the create a new body morph window. Unexpand Michael 2 in the left hand window of The Tailor 1.5. Expand M2 to M3 to The Freak in the left hand window of The Tailor 1.5 to show the following: blMilMan_M3_M2 blMilMan_M3_M2 Groups default Materials Morph targets M3 The Freak Unselect M3 in the left hand window of The Tailor 1.5. Select The Freak in the left hand window of The Tailor 1.5. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. If all ready selected skip the next step. Click on create morphs in The Tailors 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter The Freak in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M2 to M3 to The Freak in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE M2 TO M3 FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load M2 to M3.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/Mannequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load Michael 2 in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan_hip.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand M2 to M3 in the left hand window of The Tailor 1.5 to show the following: blMilMan_M3_M2 blMilMan_M3_M2 Groups default Materials Morph targets M3 Select M3. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter M3 in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M2 to M3 in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5. CREATE M2 TO THE FREAK FIGURE. Open The Tailor 1.5. Click on file in The Tailor 1.5's main menu. Click on load base figure in the file menu. Load M2 to The Freak.pp2 in the open the base figure window. The file will not show up in the Poser 5/Runtime/Libraries/Props/Mannequin folder as The Tailor 1.5 only shows files with the cr2 file extension. So you will have to type it in. Click on open in the open the base file window. Click on file in The Tailor 1.5's main menu. Click on load the dress in the file menu. Load Michael 2 in the open the dress figure window. Click on open in the open the dress figure window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. If a file not found window pops up: A. Click on the folder icon in the file not found window. B. Load blMilMan_hip.obj from the original directory in the browse window. C. Click on open in the browse window. D. Click on ok in the file not found window. Expand M2 to The Freak in the left hand window of The Tailor 1.5 to show the following: blMilMan_M3_M2 blMilMan_M3_M2 Groups default Materials Morph targets The Freak Select The Freak. Click on create morphs in The Tailor 1.5's main menu. Click on morphs selected are like one body morph in the create morphs menu. Click on create morphs in the tailor 1.5's main menu. Click on create morphs in the dress in the create morphs menu. Enter The Freak in the create a new body morph window. Click on ok in the create a new body morph window. Click on file in The Tailor 1.5's main menu. Click on save the dress as in the file menu. Enter M2 to The Freak in the save as window. Change the directory to Poser 5/Runtime/Libraries/Character/Mannequin in the save as window. Click on save in the save as window. Click on save with new morphs as they are in the save option window. Click on save in the save as window. Close The Tailor 1.5.
nightfir ( ) posted Fri, 28 November 2003 at 12:54 PM
Here is Mike 2's born to be wild jacket with the Mike 3, and The Freak morphs applied to it, on the Mike 2 figure with the Mike 3, and The Freak morphs applied to it. Mike 3 is set to 0. The Freak is set to 0.
nightfir ( ) posted Fri, 28 November 2003 at 12:55 PM
Here is with the Mike 3 morph set to 1, and The Freak morph set to 0 on both the figure, and the jacket.
nightfir ( ) posted Fri, 28 November 2003 at 1:01 PM
Here is with the Mike 3 morph set to 0, and The Freak morph set to 1 on both the figure, and the jacket. Set scale on the jacket to 101% (body). Oh, this is what I did first: Loaded the jacket, then M2 to M3 to The Freak. Then conformed the jacket to M2 to M3 to The Freak (the first step with Mike 3, and The Freak morphs set to 0).
nightfir ( ) posted Fri, 28 November 2003 at 1:11 PM
This tutorial is rather complicated, and I hope I got everything in correctly. I was working on it from around 4 pm to midnight the day before Thanksgiving, writing it down with pencil. Just typed it in on computer, and checked it out twice. If you have any problems, or questions let me know, Brad.
MachineClaw ( ) posted Fri, 28 November 2003 at 2:36 PM
And they said it couldn't be done. hahaha. Yes very complicated, but the first to do anything is complicated. nice work. An idea that needed to be tryed and played with. Now if my feeble little brain can understand it all I'd be set. Thanks again for the undertaking, should prove interesting.
Mitch1 ( ) posted Fri, 28 November 2003 at 5:12 PM
Thanks for putting this together nightfir.
igohigh ( ) posted Fri, 28 November 2003 at 10:33 PM
OK, this is gonna take me a while to absorb but...since M2 and M3 are involved, then could Stephanie and V3 be thrown into the mix too?? I mean like for robes, boots, and other fantasy gear? (boy, now my blonde brain REALY hurts!)
PabloS ( ) posted Sat, 29 November 2003 at 7:57 AM
doozy ( ) posted Sat, 29 November 2003 at 9:38 AM
If I have M3 but not M2 am I out of luck getting M2 clothes to fit M3?
nightfir ( ) posted Sat, 29 November 2003 at 12:41 PM
Found some problems with the character figures.
  1. The M2 to M3 to The Freak, The M2 to M3, and M2 to The Freak get distorted when changing
    morph settings.
  2. Posing the character figures does not work. The figures get distorted as I change the
    morph settings such as The Freak to M2.
  3. Texture maps are not going on character figures correctly. I can put a M2 texture on
    lets say the M2 to M3 to The Freak character figure, and it fits right if I have the
    M3 morph set to 0, or 1, or if I have The Freak morph set to 0 or 1. However if I
    set the M3 morph to 1, and apply a M3 texture it does not work. Same with The Freak.
Character figures in question are:
M2 to M3.
M2 to The Freak.
M3 to M2.
M3 to The Freak.
The Freak to M2.
The Freak to M3.
From these results I guess the best thing to do is forget using the character figures for now
at least in Poser. Not sure if the figures will show up correctly in other applications such as,
Vue, Bryce, or 3D Studio Max, etc or if they show up correctly in other versions of Poser, with
different service release packs. Sorry about the character figure problems, I should have done
a bit more testing before I put the tutorial out. Shades of Poser! LOL!
The prop figures work ok tho, along with transfering stuff to clothing items have no idea as to why.
The clothing can still be used with multiple figures as follows:
Did not use the M3 JP pose settings on anything tho it should be used, or at least tried.
On a M2 piece of clothing with a M3 morph, load the clothing item into Poser, Set M3 to 1,
load M3 into Poser, and place the clothing item on M3.
On a M2 piece of clothing with a The Freak morph, load the clothing item into Poser, Set
The Freak to 1, load The Freak, and place the clothing item on The Freak.
On a M2 piece of clothing with both the M3 morph, and The Freak morph, change either M3 to 1,
or The Freak to 1, and load either M3, or The Freak, and place the clothing item on the figure.
Do this for other clothing items with the different morphs applied such as:
M3 to M2, M3 to The Freak, M3 to M2 to The Freak, The Freak to M2, The Freak to M3, The Freak to M2 to M3.
Pics show M2's born to be wild jacket with M3, and The Freak moprhs applied to it placed on
the normal The Freak figure.
The Freak right collar taper = 10%, left shoulder = invisible, left forearm = invisible.
Leather Jacket body ytrans = .030, right forearm side to side = -15, body The Freak = 1.070. There is a
little poke thru in a couple spots which Photoshop can cure.
The last three pics show the character figure M2 to M3 To The Freak with The Freak morph set to 1, and with
the come here pose applied, and a M3 texture applied to the M2 to M3 to The Freak character figure with
the M3 morph set to 1. This shows the problems I'm having with items 1, 2, and 3 above.
If anyone has ideas on how to fix the problems in 1, 2, and 3 please let me know, so I can correct the problem,
and give the info to other poser users. Thanks, Brad.
nightfir ( ) posted Sat, 29 November 2003 at 12:42 PM
pic 1
nightfir ( ) posted Sat, 29 November 2003 at 12:43 PM
pic2
pic 3
nightfir ( ) posted Sat, 29 November 2003 at 12:44 PM
pic4
nightfir ( ) posted Sat, 29 November 2003 at 12:45 PM
pic 5
nightfir ( ) posted Sat, 29 November 2003 at 12:46 PM
pic 6
pic 7
nightfir ( ) posted Sat, 29 November 2003 at 12:47 PM
pic 8
nightfir ( ) posted Sat, 29 November 2003 at 12:53 PM
Igohigh: not sure about Stephanie, and V3. It could work have not got that far yet. Doozy: If you don't have M2, you can still use the M3, and The Freak stuff. Brad.
