Wed, Jan 29, 11:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: Could really use some help. Joint Params, I think.
AofD ( ) posted Sat, 29 November 2003 at 6:43 PM · edited Wed, 29 January 2025 at 11:35 PM
Attached Link: http://www.ironcladstudios.com
Hi I've been having this little problem with a set im currently working on. No matter how I adjust the joint params when bend the draw part I cannot get the whole part to bend evenly so that is stays aligned with the sheath. Thanks, Psykes
AofD ( ) posted Sat, 29 November 2003 at 6:45 PM
Oh yeah the sheath is a smart prop parented to the body part named "draw" if that helps any.
PheonixRising ( ) posted Sat, 29 November 2003 at 7:22 PM
KK this is actuallu pretty easy. The center is not alinged exactly center inside the strap. The center if off distorting the rotation. The red/green "handlebars" need to have their center in the center of the segment width. Rules of Joints Everything inside green bends with rotation Everything outside of red does not bend with rotation Everything between red and green blends during rotation. For a possibly smoother blend add more part segments. My experience is that you need rougly 10 to 12 polygons for a smooth circular curve
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
PheonixRising ( ) posted Sat, 29 November 2003 at 7:42 PM
Here is a sample of what you are looking for
AofD ( ) posted Sat, 29 November 2003 at 8:29 PM
Thanks so far the info was a bit helpful. I still seam to be getting the same problem though, its a little bit better on the upper part, the larger strap, but the low part (string) still gets all outta whack... I had a thought though, could the proble be the way the strap is sharpe? the fact that is does point straight down or something? or would cutting it a differnt way make it work better you think?
PheonixRising ( ) posted Sat, 29 November 2003 at 9:49 PM
add more bendable segments. :P
Letterworks ( ) posted Sat, 29 November 2003 at 10:23 PM
ping
AofD ( ) posted Sun, 30 November 2003 at 1:09 AM
Well now I feel like a dolt, turns out all it was is i messed up the orientation at some point... Thanks again though dude, it was useful info either way. Psykes
