Sat, Feb 8, 6:32 PM CST
Subject: Nore realistic water flow? WIP
amethyss ( ) posted Sun, 30 November 2003 at 11:34 AM ยท edited Wed, 05 February 2025 at 6:34 AM
I'd like to learn more about creating more realistic water falls.Tutorials? Easy Methods? You can see in this the trouble I am having.
Painting: The art of protecting flat surfaces from the weather and exposing them to the critic_____website
ibassplayer205 ( ) posted Sun, 30 November 2003 at 11:50 AM
I think the actual water fall looks pretty good, me thinks the only 'problem' is the splash at the bottom of the fall. sorry, but i have no idea how you could fix that. but the fall looks very nice, fix up the splash and it will look great
rickymaveety ( ) posted Sun, 30 November 2003 at 11:53 AM
It looks like you are awful close to a solution on your own. That looks quite good. Some more detail in your waterfall terrain would be good (what resolution did you start with?). Also, maybe a tiny bit of mist at the intersection of the waterfall with the water.
Could be worse, could be raining.
TheBryster ( ) posted Sun, 30 November 2003 at 6:23 PM
Amethyss: You should be creating tuts for us poor saps! This one is brilliant. I need one just like it for a project I'm working on right now!
amethyss ( ) posted Sun, 30 November 2003 at 8:47 PM
Wow what feedback...I thought it looked cheesy,but I am postworking it for some spray,and it is getting better.It is lattice work with some erosion,twisting and texture editor effects.
CharleyD ( ) posted Sun, 30 November 2003 at 11:33 PM
a little more sparkle to the waterfall could add something...just a suggestion, as it's near perfect the way it is... more splash and mist, as others have said would do a lot too....great work!
clay ( ) posted Mon, 01 December 2003 at 12:31 AM
You are really close, I would use two animated layers on this, one with an animated cloud layer for mist and then animate the water using the offset function in the mat lab.
Do atleast one thing a day that scares the hell outta ya!!
danamo ( ) posted Mon, 01 December 2003 at 3:24 AM
This already looks quite good! I like the way your waterfall refracts an image of the wall behind it.
Gog ( ) posted Mon, 01 December 2003 at 5:03 AM
Attached Link: http://www.petersharpe.com/
Try using metaballs and/or booleaned terrains for the splash the image shows the booleaned terrains bit. two terrains turned upside down, made solid for boolean and then booleaned to give a splash, I've reduced the transparency of the water mat for this image. (Idea from Peter Sharpes Tuts)
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
mboncher ( ) posted Mon, 01 December 2003 at 3:32 PM
I'd give it a little, not much, fog around it to show water that's been turned into aerosol. It'd help mask any problem areas you see, as well as add realism. Otherwise, do a tut or "deconstructed" scene. IMHO
