Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Vicky 3 does not work the same way as Vicky 2. I am afraid that you have to but the pack of Facial Morphs for Vicky 3 and then click on each one to add the dial function to the figure. The expressions for Vicky 2 won't work on her. There are tutorials at Daz and elsewhere which will explain this better than I can.
If you are getting blank dials you must have saved the character back to the library - they are hidden in the figures that the DAZ installer puts into your library. To re-hide them you need to use DialCleaner, on the V3 product page. If you have more than one V3 to V2 figure that might also explain why sometimes you get the map request and sometimes you don't - one of them has a map applied and the other doesn't (the default is no map). As elgyfu says, you need the Head Morph Pack from DAZ to apply expressions.
Attached Link: http://www.visual-redemption.com/redemption
I have the Victoria 3.0 from DAZ which comes with the V-2 character... how do I apply facial expresions to her? It seems sometimes I can get them to work and other times I can't... there are all these injection dials under morph with no titles and they do not appear to do anything... somethings buggy I'll bet? Out of the expresions in the library which one should I be using to apply facial morphs to Vicky 2.0 I really have less than no clue when it comes to poser... one day perhaps, a little step at a time... It's just frustrating when something works one day and then not the next. For instance, sometimes when I open the Poser file it asks for her suit bump map and other times it does'nt... any clue as to why it does that? Sorry... I have too may questions. Michael
