Sat, Jan 11, 5:52 PM CST
Subject: .Obj file will not load with character......
frost ( ) posted Wed, 16 August 2000 at 2:05 PM ยท edited Sat, 11 January 2025 at 3:16 PM
I've downloaded the Storm and Psylocke figures from 3d-cc but when I open them it gives me the message it can't find none of the .obj files that are associated with them. All the other stuff I've downloaded that uses .obj files open with the characters and are fully poseable. So when I import them in myself manually they appear smaller and non poseble. Can somebody tell me what am I doing wrong. Like always any help will be greatly appreciated. Frost
Mason ( ) posted Wed, 16 August 2000 at 3:36 PM
The obj meshes maybe encoded usuing objaction mover. If the zip contains a .pcf file then the file needs to be decoded. The objaction mover utility written by MAZ (which is awesome BTW) can be found in the freestuff utility section. Also, if you are using a foriegn language version the directory structure maybe different requiring you to edit the cr2 file.
PhilC ( ) posted Wed, 16 August 2000 at 3:36 PM
Do you have the OBJ file for this character? If so is it in the correct folder? Not sure what the correct folder is? Open the CR2 file in a text editor and near the top you will see the object file path. Ensure that the file is positioned to match. Hope this helps, PhilC www.philc.net
steveshanks ( ) posted Wed, 16 August 2000 at 3:49 PM
also check the zip isn't creating new folders .......Steve
