Tue, Feb 18, 1:00 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: My image needs assistance, rendering issues I think!!!??
pendulum ( ) posted Wed, 03 December 2003 at 2:25 PM · edited Tue, 18 February 2025 at 9:45 AM
Hi again everyone, the image I have attached is a high quality render with global illumination etc. The objects are on a wall, and they are lights faciong up and down, with globes inside them set to around 600% strength, to make the walls light up nicely. I also have a blobe in the room set to around 70% to give some ambient light. I can't work out why I am getting those sections of light right behind and beside the lights' shadow on the wall. Its really irritating me. I want to just have a nice dark shadow there, but instead I am getting these yuk sections of light. How can I avoide this? I still want to use GI Rendering. Scott Richardson
pendulum ( ) posted Wed, 03 December 2003 at 2:40 PM
Also, attached is an earlier render, which looks nothing like what I wanted, without Global Illumination etc. It has less of the light behind/beside the lights tho. Scott
cckens ( ) posted Wed, 03 December 2003 at 5:37 PM
Scott, looks like you have some bleeding from the internal lights. I'm going to make an assumption that they are spheres with a glow scaled to 600%. If the sconce/fixture has any open facets along the way, that would cause the bleeding. If not, I would recommend making the globes in the fixture smaller. Size is not an issue in indirect glow lighting and if any of the glow facets are intruding on the fixture that would also cause the bleeding we are seeing here. Ken dork.gif
pendulum ( ) posted Wed, 03 December 2003 at 6:00 PM
there are no gaps in the outer fixture, so it must be the globes. I have NO glass spheres around the globes... just the globes themselves in there. I will shrink the globes and add some spheres and let you know how I go. Thanks Scott
mateo_sancarlos ( ) posted Wed, 03 December 2003 at 6:06 PM
It looks like caustics. There was an earlier thread about this; will try to remember which one it was.
pendulum ( ) posted Wed, 03 December 2003 at 6:45 PM
yeah it looks like caustics to me too.. but.. alas.. caustics is turned off, and nothing is made of glass here. I am guessing that it is the radiosity/global illumination that is causing it. If you look at my 2nd image, you will notice small highlights from lights, but in the GI one, the lights are the really bright bits that I dont want... its a mystery I tells ya. Scott
cckens ( ) posted Wed, 03 December 2003 at 8:45 PM
Scott, If you've got a free few, try to post a wireframe of the image. Should only take a few secs to render. This will give us a good idea of how the scene renders out... Ken dork.gif
pendulum ( ) posted Thu, 04 December 2003 at 2:21 AM
hi guys... have attached some more images. I have shrunk the globes, added spheres, and done a wireframe shot. I have overlayed my questions on the image there. Scott
pendulum ( ) posted Thu, 04 December 2003 at 2:23 AM
here is the image
MarkBremmer ( ) posted Thu, 04 December 2003 at 10:33 AM
Turning off Interpolation should help this. Mark
pendulum ( ) posted Thu, 04 December 2003 at 1:36 PM
thanks Mark.. rendering agai now.. will let you know how it goes Scott
3ddave44 ( ) posted Thu, 04 December 2003 at 2:32 PM
I believe the manual talks about this in the section talking about interpolation or global illum. It say that bleeding can occur if the object's thickness is thin... But also I think turning interpolation off will help - I was getting boxy artifacts that were eliminated when interpolation was off. The image took longer to render however. Good luck.
pendulum ( ) posted Thu, 04 December 2003 at 9:41 PM
Yup! it fixed my problem. thanks guys, glad I had you guys to help me out just for interest... why on earth does light bleed through a solid (thin) object? Is that a problem with the rendering engine? Scott
MarkBremmer ( ) posted Thu, 04 December 2003 at 10:26 PM
When the program is allowed to interpolate (round-off numbers), instead of specifically calculating the light paths, it does a "close-is-good-enough" calculation which saves time. Basically, it puts the light in the correct general area. On many occasions, the time savings is worth it. However, when you have thin walls on an object the "close-enough" calculation can allow light to pass through objects - especially when the intensity is cranked up.
