Forum Moderators: Staff
heyas; um... build the teeth and gums (and tongue), and insert them into the head. make sure the head mesh has a mouth cavity, of course. nothing really needs to be connected, just jam the gums up into the mouth cavity. give the gums/teeth new materials, but make their group the head, and you'll be fine. :) in fact, it would be better if your model were constructed that way, rather than one continuous mesh. it'll be easier for morphers to separate the various parts to work on.
Zygote builds them as a seperate body part. Actually, it is part of the figure hierarchy, so they are part of about a dozen body parts. Only uber expensive programs can handle obj files with a hierarchy, so they grossly simplify it before they UV map it. Zygote accidently shipped the nude asian female and nude black female figures with the full hierarchy. It didn't work very well as a Poser figure but it was fairly interesting to poke through it, before they fixed it and sent me the new one.
Slightly off the subject, but I think Zygote missed the bus in not making the upper and lower teeth separate groups, like the eyes. Vickie needs to be able to pull her lips back and leave her teeth closed, and then open her teeth indepandantly, something I've never seen anybody do in a morph, as it it just to hard to break out the mesh in that area. But it would have been easy when they were building the figure.
heyas; you know you can use the grouping tool and magnets... put the skin and mouth-skin into a group, and the teeth/gums materials into another (are the gums separate or part of the 'mouth' material? can't remember.) anyway, once you have the skin group separated from the teeth/gums, you can tell the mag zone to only affect the group. so you could use a magnet to pull the lips and facial skin all around anywhere, and leave the teeth where they are.
Is there some wonderful secret to how Zygote embedded teeth into there models? I am just woondering as I am trying to do a model now that requires I learn and quick if I am to finish it. Your help is much appreciated.
