Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 10:51 pm)
Iderdnev, I hope someone knows of a utility or Python script that can do what you want, if not then perhaps the ideas below will at least be better than compiling the list by hand. In Poser 4 select an actor (body part), then from the Edit menu select copy. Paste the clipbord contents into a text editor. The result will be a listing of all the none-hidden channels in that actor. Normally the morphs will be listed first, then the Taper channel, then the scale and rotate channels. Here is what you get if you copy and paste from Posette,s chest:
Chest 0 Small Spline 0.0000
Chest 0 Large Spline 0.0000
Chest 0 Droop Spline 0.0000
Chest 0 Hi-nipple Spline 0.0000
Chest 0 Cleavage Spline 0.0000
Chest 0 heroine Spline 0.0000
Chest 0 taper Spline 0.0000
Chest 0 scale Spline 1.0000
Chest 0 xScale Spline 1.0000
Chest 0 yScale Spline 1.0000
Chest 0 zScale Spline 1.0000
Chest 0 yrot Spline 0.0000
Chest 0 zrot Spline 0.0000
Chest 0 xrot Spline 0.0000
Obviously you can edit this to leave a list of morph targets, but you would have to repete the procedure for each actor. An alternative to the above may be to use the free utility Mat Pose Edit to make a pose file containing only morph targets, zero those morph targets. Then you should be able to open the resulting pz2 in a text editor, and use its search and replace function to delete much of unneeded stuff in the pz2, and with a bit more editing by hand you will be left with a list of morpf targets.
I'm not positive what you are trying to do. If you just want to print a list, you could save a zeroed pose to the library of the figure. Be sure to include morph targets when you save. Open the resulting pz2 in a text editor, then search and replace the following text with nothing: { keys { k 0 0 } } then search and replace the following text with nothing: targetGeom If you include the spaces in your search, those will be removed as well. This will give you a list with all actors that shouldn't require much editing. Beth
Hello, I want to print (or edit in Excel) the names of the mophtarget dial from a poser model. Anyone know how I can make that?
