Bryce F.A.Q (Last Updated: 2024 Oct 30 3:44 am)
Hi, first of all: writing in captions the whole time is defined as screaming. Please stop it, my ears are yet bleading. ;-)) For the meshes: you can find those in the freestuff here. Just do a search, there are wonderful models. And look at 3dcafe.com, which has a huge freebie section too. Greets, Jimi
Hello Jimi is right typing in CAPITALS is being rude to others, avoid doing so. If your going to do searches in data bases etc., you will need to check you have the right English spelling to start with. I presume you mean 'Snooker', as in 147 breaks etc.,, and 'Snooker Cues', the wooden implement used in the manuacture of those 147 breaks. Go to Bryce Freestuff, look for 'Search' and click. In the new window type in Snooker, tick non-commercial and stand-alone and you should be presented with an image of a snooker table with balls and cues, textures included. This can be downloaded onto your computer for your private use. Bye now.....Dennis
Attached Link: http://www.bryceworks.com/btopalms/btoplams.html
I have some Bryce 5 Palms at link above. Best; DanGroan..............
What does NAWAF mean?
I got there first. Good Grief.......... All power to you Mr.Al-Mohammad. As regards textures of Snooker Balls, you don't actually need to do a lot, they have no numbers to worry about and just a single colour per ball. A lttle reflectivity is desirable so the easiest thing to do is create a bryce sphere, you can here resize the sphere to your required size., Click the 'E' in the panel next to the sphere, this brings you to the Materials editor. Select category Simple and Fast and from the resultant choice select Red Shiny Plastic, Click the Tick and your back in the Bryce window with a Red Snooker Ball. Of course you need fifteen of these, so while you original ball is still selected go to EDIT/Multi-Relicate and put in 15. In the middle box, top line type a 5, all the others should be zeros, the size boxes should all be 100%. Press o.k. and you should now 15 Red balls albeit on top of each other. Select your original Red ball and click the 'E', you can see it's colour in the 'diffuse' spot, to change it click and hold while selecting new colour. You will need a yellow, green, brown, blue, pink, black and a white 'cue' ball. Sorry I'm no good at making chalk!! Bye now........Dennis
HEY GUYS. WHAT'S GOING ON IN HERE? SORRY, BUT I CAN'T HEAR ANYTHING. BEEN BLOWING THINGS UP ALL DAY. DID YOU SAY SOMETHING ABOUT SMUCKERS PEANUT BUTTER BALLS AND HAND MODELS? I THINK 3D CAFE HAS A FREE HAND MODEL. hehe. like I could resist. Hi J.
Because I like to blow $%&# up.
Don't fear the night. Fear what hunts at night.
Okay to clarify for those of us that are not english by nature, let's use 'UPPERCASE', and 'lowercase' letters.... Derjimi, your english is fine, it's the language that's screwy, check this out; Capital, a city or town that is the official seat of government, money used to found a business, the upper most portion of a column or pillar supporting entablature, an uppercase letter occuring as the first letter of a proper name or first letter in the first word in a sentence, principle investment or assests, answer to the question 'how are you today?'........ We have a bunch of words, like that.
Bryce Forum Coordinator....
Groan....
If I had the captital, I'd go to the capital and see 'The Capitol' while consuming capacious cups of capuchino(sp) and while capitulating to the circumstances rather than decapitatng over captious comparisons of capitulum to capitoline, consider constraining my capricious capriccio. Not t'change the subject or anything but weren't we all talkin 'bout palm trees?
HALLOW I WANT TO ASK ABOUT PALM TREE MODELS WHERE CAN I FIND IT ? AND I NEED SNOKER RACKET MODELS ? AND TEXTURES SNOKER BALLS ? BEST REGARDS NAWAF :) THANKS
