Mon, Jan 6, 12:44 PM CST
Subject: Plugins for poser morphs
tajshan ( ) posted Thu, 04 December 2003 at 11:53 PM · edited Sat, 04 January 2025 at 2:18 PM
Hi does anyone out there know of any plugins that can be used to export .objs back to poser as morphs? In some programs when you do this, the vertices points gets outta whack and poser won't accept it, but hear there are plugins that will correct the numbers. Thanx fellas
PheonixRising ( ) posted Fri, 05 December 2003 at 3:31 AM
The plugin would correct the winding order of the polygons. Explosion morphs happen when Poser can't figure out what polygons belog where on the morph. I have heard of one for Lightwave but never heard of any others. I know UV Mapper pro has a reorder function but have no idea really what it does or what it is for. Maybe that might work?
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
ockham ( ) posted Fri, 05 December 2003 at 9:35 AM
The winding order is not really needed to input a morph. My Loader script takes a "back-door" approach to loading an OBJ morph, which seems to be less finicky than the standard Poser method. It may not solve your particular problem, but it will load some MT OBJ files that Poser normally rejects. Loader also does many other useful tricks. It's sold through Synergy3d.net, under Poser Accessories, if you want to try it.....
My python page
My ShareCG freebies
