Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Sep 18 12:22 pm)
I think you could up the contrast a tad. As it is the tree's are a bit greyish. I think it would look better if the dark area's in the foreground would be black or near black. But that's just my opinion :)
What is a friend? A single soul dwelling in two bodies. -
Aristotle
Glass Eye Photography =- -= My Rendo Gallery =-
I was playing with the "unsharp mask" in PSP7 trying to sharpen and lighten. The original is much darker but it came out when I adjusted the contrast/brightness. I would hate to trash these but seeing as it is lacking both sharpness and light... I am posting the original here, feel free to play with it, as I am sure I will.
Kewl Beans! I like that last one there, the colors are just as beautiful as the sky was yesterday. Got a couple sky shots this AM, didn't have time to actually do a shoot this morning! :( Funny, on the lcd on the camera when I took these, didn't look as dark as they actually are! I have found a setting for "curves" in PSP, I can do some screen shots if you don't have PSP7! Let me know. I have had some pretty abstract results with this pic using the different effects in PSP, have been thinking on using the eye candy filter on this and seeing what I can do in there.
brenda, PSP has curves, contrast, clarify & noise reduction, similar to PS, ya just gotta look for em... look under "adjust"-> brightness & contrast -> curves also clarify is there add & remove noise is under adjust too, as well as hue & saturation just take a shot & try out every tool you have to familiarize with what they do & where they're located nice silhouette shot here gf good postwork Donald :]
Attached Link: http://www.luminous-landscape.com/tutorials/command_primer.shtml
Nilla - what kind of camera are you shooting these with? As for curves, Luminous Landscapes has a great primer on it. Check the link above. All I did in that first one was to adjust the black and white points (in quick terms, I pulled the bottom-left marker horizontally to the right and the top-right marker horizontally to the left). -=>DonaldThank you both! Will be sure to check out that link, thanks Donald! And Cyn, I had already found most of those settings, have been playing around with them to try to find the best way to bring out the colors without losing anymore clarity. Donald I am using a Sony Mavica that I bought almost two years ago. I know that I need to upgrade, but I won't be doing that until spring! :) Thanks again! Hugs! Brenda :)
