Sat, Jan 25, 1:45 PM CST
Subject: HELP! UV Mapping Nightmare!
RKane_1 ( ) posted Sun, 20 August 2000 at 6:14 PM · edited Fri, 10 January 2025 at 8:07 PM
I am trying to remap the P4 Male for my new Chaney figure coming out soon. I did and used UV Mapper to do so (Great prog, btw, thanks Steve and gang!) I saved the .obj (yes, I backed it up and moved that backup file) Eliminated the .rsr for both .obj and .cr2 file and then opened Poser and tried to render with a new map BUT it looks like Poser is looking to allocate the texture like the OLD texture so its quite screwed up. I did everything correct (for all I know) and it happened again. I DID reassign some areas to be new materials and saved those changes in the .obj but the Materials Editor does not show them AND shows Materials that are no longer there (like the materials for the old eyes which I have replaced). What am I doing wrong?
Mason ( ) posted Sun, 20 August 2000 at 6:19 PM
Chweck the cr2 to make sure there are no groups added. A groupd basically adds the UV info into the cr2. Its like adding a prop.
RKane_1 ( ) posted Sun, 20 August 2000 at 6:31 PM
How do I do that? When I open CR2Editor, what do I look for?
Cage ( ) posted Sun, 20 August 2000 at 8:46 PM
Look for a "GeomCustom" reference under the Head in the .cr2.
RKane_1 ( ) posted Mon, 21 August 2000 at 12:04 AM
And delete it?
RKane_1 ( ) posted Mon, 21 August 2000 at 1:25 AM
WAHOO! Thanks Mason and Cage! You guys should right some tuts on this wacky crap. I was near pulling my hair out. Thanks so much!
bloodsong ( ) posted Mon, 21 August 2000 at 5:10 PM
er... if you delete the geomcustom, you'll lose your groups. also, you'll need to replace it with the... well, look at the other body parts, you'll see. the storagewhatsit and the geomhandler thing.
