I think this is lovely, and it looks soooo cold! :-)
The only recommendation I can think of is that the solid snowflakes close to the camera have a matte material, and I tend to think of snowflakes as icy-transparent. You could re-texture them and just plop-render those areas, to avoid a long re-render of the whole scene.
Two other questions:
I'm not a big fan of the largest flakes, but if you like 'em, no prob. I would also like to see a frost trail on the ice behind the 2 skating fairies, I think it would add to the sense of movement on their part. I guess this would have to be added in post, but if you like the idea, you might find a way to do it inside Bryce. I really like this one, Electro. John
The bird is a cardinal but with the color perspective on it's kind of dark. The dark snowflake is one of the pinecones. I duplicated the one in the foreground and the needles, offset in y 0.2, and added a snow mat to make them look like snow was building up on top. I did the same with the pinetrees. There is a trail of snowflakes leading up to the girls feet. It's applied to a square with a transmap. Unfortunately, the iceburg texture on the ground plane washes it out. I agree the big snowflakes are not working. The others were built up on a layer using PSP and picture tubes. I rotated the layer as I pasted so all the flakes aren't straight up. I'm thinking of also creating a blue glow layer first with streaks and lights coming back from the figures before putting down the snowflakes. Thanks for the input. I'm rendering now.
This is just about how I want it. I may add another girl peeking around one of the trees. This is a render with sunlight off. There's one blue light on the ground plane behind the camera right and one white light at a 45 to the left behind the camera. All other colors are from the high ambience. Color perspective is set ar R5 G5 B6 so everything goes white at a distance. Suggestions and comments welcome. I'm kind of cross eyed at this point from looking and may be missing something.
