The DPI are not important at all. You only need this feature if you render high resolution images especially for prints. In this case, most Printer jobs don't print highter then 300 DPI anyhow. To have a smooth image, select USER SETTINGS from the render options and bring ALL the antialiasing sliders to the hightest point. Beware render time! Now, if you need your image for a print out, there is no need to render so smooth. The print will not show the difference. Have a look in our backroom "archtips" and search for printing. Guitta Guitta
You'll probably find that your grainy renders are those using the volumetric atmosphere model. Generally, you need to crank up the render quality for scenes using volumetric atmospheres, volumetric/soft-shadowed lights or depth-of-field to avoid the graininess. You can get away with much lower anti-aliasing if your scene uses none of the above.
jwhitham: you must not have a flat screen LDS monitor is all I can say there is a big difference when upping the Dots per inch more dots more quality pretty simple to understand really and I have seen the difference on many of my customers PC to each his own this is a very minor point to be sure. Thanks for your input.
I have been using Vue 4 and Pro for some time and the results of finished renders vary and I can't work out why. My last render was smooth (no grain or noise) but my current scene renders with noise {or pixelisation}. I always render at high resolution: 5000 X approx 3500 with 300dpi (have tried 600dpi but made no difference)I normaly use the 'fine' setting. Has anyone here please got any idea why the render quality is like this and what causes it. What settings do you other guys use? Thanks for taking the time to read this. Tony
