LindaB: Your shader probably has a high reflection value in some areas, but also from what I can see in your render there is nothing to reflect in the scene. What you need is a background to be reflected. As a first try I would go to the properties for the scene and in the background choose the bigradient. This way you will see how the shader looks with something to reflect. Hope this helps.
