Sat, Feb 8, 5:40 AM CST
Subject: Negating timeline stuff?
Ghostofmacbeth ( ) posted Fri, 25 August 2000 at 8:29 PM · edited Sat, 01 February 2025 at 2:44 PM
Is there any way that you can getrid of an acidental timeline thing? Those dang blue dots and stuff. Somehow it started and I have to keep advancing the frame to get the figure back to the right size and position .. Thanks
Hawkfyr ( ) posted Fri, 25 August 2000 at 11:49 PM
I'm not sure, but I seem to remember something about selecting it in the Advanced Motion Lab, and hitting the backspace key. or was it the delete key?..... anyway maybe give em both a try and see if it works. Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
clay ( ) posted Sat, 26 August 2000 at 4:16 AM
Select the object go into the AML and either collapse it's window to see all the options, or hold down the shift key and delete all eventmarks, I would do the first thing heheh, find your point in time then go to the AML just click the eventmark and delete it it out,
Do atleast one thing a day that scares the hell outta ya!!
Ghostofmacbeth ( ) posted Sat, 26 August 2000 at 8:35 AM
Motion Lab .... Gotta find it since it is something I never use but thanks. I will see if that will work.
Hawkfyr ( ) posted Sat, 26 August 2000 at 10:35 AM
Toggle the Pallets at the bottom of your screen to revael the animation pallet, and clik on the little little Icon to the far right to bring up the lab or go to "Oblects>motion lab.from the menu at the top. you could also use CTRL + T (windows) But I'm sure your mac has a similar command. the AML has the ability to fine tune and tweak your animations. but it can be a bit intimidating at first. Good luck Ghost Hawkfyr
