Sun, Jan 26, 12:34 PM CST
Subject: Import from Poser Problems
mmajor ( ) posted Sat, 27 December 2003 at 10:20 AM · edited Sat, 25 January 2025 at 7:32 AM
Happy Holidays!
I need help, directions, /and or advice.
Whenever I import .obj files from Poser 4 into Bryce I loose eyebrows and eyelashes. I've done everything I can think of including using a freware piece of software caled Grouper 1.4. I'm frustrated, do you have any recommendations?
Thanks,
mmajor
Aldaron ( ) posted Sat, 27 December 2003 at 1:54 PM
You have to re-apply the transparency maps to the lashes and brows in the material editor.
chohole ( ) posted Sat, 27 December 2003 at 2:12 PM
I actually never use grouper. I do it the hard way, but what I have done is make a tryout obj of each poser fig I use, and then pulled them apart in bryce and made a note of which number applied to each part, because they can be different. I have that list safely stored in my cd rack, so it is there if I happen to forget. A tip, when applying trans maps to eye lashes I find it best to tick so they don't transmit shadows.
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
_akaMycal ( ) posted Sat, 27 December 2003 at 6:12 PM
Attached Link: http://akamycal.com
how do you apply the transparency maps once in bryce?
chohole ( ) posted Sun, 28 December 2003 at 3:50 AM
I do it like this. Make sure you apply the lash trans in the alpha channel in the texture editor
