Mon, Dec 23, 7:33 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: help with joint problems?
shadowcat ( ) posted Sun, 28 December 2003 at 5:40 PM ยท edited Mon, 23 December 2024 at 4:06 AM
I'm not sure when or how this happened, but sara's hand is have joint issues now. Other hand is fine & symetry doesn't fix it.
SamTherapy ( ) posted Sun, 28 December 2003 at 5:45 PM
Nice. I had a similar thing happen with SP's right leg today. Had to reboot before the problem cleared up. If it helps any, I had been applying V3 poses to SP. Have you been trying out other models' hand poses on Sara? V1 in particular could have caused this; the model's hands were not jointed correctly and all V1 hand poses had an offset built in.
shadowcat ( ) posted Sun, 28 December 2003 at 5:47 PM
obj is fine. I've tried to start from scratch with the original sara cr2 but then I had other more serious problems (head, eyes, & chest warping) Don't know why. really would like to fix the current cr2, because other then the fingers everything else works perfectly. I even have the head morphs sorted the way I want them.
shadowcat ( ) posted Sun, 28 December 2003 at 5:56 PM
only other problem is a slight warp on the rCollar that I'm going to fix once I figure out what up with the hand. OK, I admit it, I'm picky.
shadowcat ( ) posted Sun, 28 December 2003 at 5:58 PM
not sure what happened, the first picture is in a zeroed pose. how would I check for offsets?
shadowcat ( ) posted Sun, 28 December 2003 at 6:54 PM
2 of 4 finger joints fixed, by zeroing out the orientation of the joints (can't explain better) wish that had worked on the other 2 joints.
