Mon, Feb 3, 8:36 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Hi all, how do you use poser transmaps in carrara
drs101 ( ) posted Wed, 16 August 2000 at 8:47 PM · edited Thu, 30 January 2025 at 12:05 AM
Hi All, hav'nt posted for a long long time, but can someone remind me how to use poser transmaps in carrara thanks Danny
MarkBremmer ( ) posted Tue, 22 August 2000 at 9:28 AM
Yow! I can't believe no ones gotten back to you on this yet. Could you be more specific? (How to apply them in the shader tree?, Does the object need to be imported in OBJ format? etc.)
drs101 ( ) posted Mon, 28 August 2000 at 4:24 AM
Hi Mark well i want to import a poser figure and aply transmaps to the hair and eyelashses, so i guess i need help with settin up the shader tree.( gettin the figure into carrara is no prob) thanks Danny
MarkBremmer ( ) posted Mon, 28 August 2000 at 8:46 AM
Hello Danny, My comments are based upon the assumption that you know how to already apply a texture map within Carrara. I'll also assume that you are importing an OBJ poser export. I've always used the UV mapper utility to create 'new' artwork for the OBJ file. I'll then create a new trasparency map and apply it to the transperency channel with the 'texture map' feature found in the shader tree. I don't want to insult you if you already know this stuff. Are you familiar with the processes that I've described? Mark
