Wed, Feb 5, 11:06 AM CST
Subject: Another "Heavenly Hair" HowTo !
mathman ( ) posted Thu, 01 January 2004 at 9:36 PM ยท edited Wed, 05 February 2025 at 10:56 AM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=6153
Hi all, I'm still grappling furiously with the "Heavenly Hair" Photoshop brushes, and still not getting great results. I've attached an image of Steph 3 with one "dab" of the fringe brush applied. As you can see, its thin and transparent. How do I get from this to a thick lustrous fringe such as can be seen in Spectre3's ad for his "Maria" textures in the marketplace (this is merely an example) ?? regards, Andrew
DarkElegance ( ) posted Thu, 01 January 2004 at 10:29 PM
you can duplicate the layer till you get the depth you wish or you can give a slight blocking in under it tweeking out the opacity till you get what you want then use the fring over it in a slightly darker shade to give the depth and highlight you are wishing.
https://www.darkelegance.co.uk/
Commission Closed till 2025
mathman ( ) posted Fri, 02 January 2004 at 12:28 AM
Thanks again for your help, Dark Elegance. I'll get there eventually ! I find that duplicating the layer makes it too dark, so I opted for your second suggestion and it has worked really well for the fringe. I also added a bit of dodge and burn for further highlights. As you can see from the image, I've still got to work out what should go on the sides :)
Cylithera ( ) posted Fri, 02 January 2004 at 2:33 AM
Looks good so far. ;)
