Could be worse, could be raining.
Ah,now those rocks sure add alot I would say(in a good way that is).And about the voulumetric slab,I was not aware of that technique at all,but now that you mention that is done that way I understand the mechanics of it.In the pics that I posted with caustics,I used a cone light with a gel,and made light visable for faked voulumetrics(my computer is slow,250mhz)for faster renders.I'll try your way though too,I cant pass up a new technique.thanks for the info.
I'd make the kelp in the background more distinct. Don't know, more specularity? Also, something is bothering me about the lights... yeah, that radial light in the front is too small. I think you should make it more like the whole window is glowing. You should use soft(-er?) shadows on it, definitely. And, yes, create volumetric lights (real or fake) for the headlights. And the ambient light could have more blue. The bottom is excellent now, with a couple of objections. What's that dark thing in the foreground? A ray? And the stones below the kelp should have a different texture, cause mossy rock looks quite unrealistic compared to the green stones in the sand. Great sub.
-- erlik
That's not a radial light, it's a reflection on the glass. The light itself is the same size as the window. Dark thing in the foreground is a rotting boat. Stones in the sand aren't so much "green" as they are slime covered. But, I'll see about doing something with that rock under the kelp. I had thought about doing something volumetric with the spots. How do you "fake" it??
Ah, I thought so after I posted my response. Hm, You should have a different reflection, not a ball. Maybe the caustic gel as the reflection map on the window? Fake light, take a cone or a cylinder and apply one of the laser beam presets from volume materials. You'll have to raise the density a lot, and then play with edge softness and fuzziness. And of course, change the colour. And the boat is undistinguishable for what it is. I see just a dark silhouette with some lighter bits in. I'd say you don't need it at all.
-- erlik
