I would, just to be sure, save the Zuzu face to the face library (if it isn't there allready), then apply the Puppet body and if it messed up the face, restore it from the face libray pose you just saved :o)
Using the Face Library may not work... The problem being that both of Zuzu and Puppet are specialty morphs, not pre-exiting morphs combined into a new face. As the Face library only saves the dial settings on the face and not the actual morphs, I'm afraid that won't work with Zuzu, though it will work with Simply Irresistable which is all dial settings and no specialty morphs. However! There is a way to do this. MorphManager should be available in the Freebies area. If not, check around on the net... Should be pretty easy to find or contact mr1_x@hotmail.com Anyway, load it up, load the CR2s for Zuzu and Puppet, then transfer the head & eyes morphs for Zuzu into the Puppet CR2. Now just save the file under a new name. You should be able to open the new file and the Zuzu settings will already be on. One comment though, the eyes changed position and size on Zuzu so if there is no morph included for the eyes, you may need to hand adjust the size and height of the eyes.
I would like to apply one of the Puppet body morphs to Koshini, but keep the Zuzu face. Is this possible? And if so, how would I do it? It changes the whole figure if I try to apply either one after the other. Thanks and Happy New Year!
