Sun, Nov 24, 3:56 AM CST
Subject: Lighting in Bryce
BellaDark ( ) posted Sat, 26 August 2000 at 3:12 PM · edited Sat, 27 July 2024 at 4:18 PM
Hi, folks!!! I've been working in Bryce for just about 2 months now, and I get really annoyed with lighting.... I fidget with the shadow intensity in the sky lab, and I've used lights... omni seems to work well most of the time, the spotlights, eeeeewwww, because I can't rotate them to shed light where I want to shed it.... And my omni for this latest project doesn't seem to be doing squat.... Is there anything else I can do? :O) Thanks.
DigitalArtist ( ) posted Sat, 26 August 2000 at 3:42 PM
Hello Picasso, Have you tweaked with the intensity and range of lighting? (Click the 'E' button when the light is selected) This could give you more control over you set of lights. Also want to try out some light gels and see how thoes effect the overall scene. :) Try holding shift and rotating the light with the rotate tool and see if that doesn't help a little (I think the increment is 25) You might also try to have More lights to produce your desired effect. Good luck! -Matt
Caligula ( ) posted Mon, 28 August 2000 at 5:48 PM
I don't use the spot lights much in Bryce. I prefer the radial lights. They work better for mood lighting. Sarah
