Wed, Dec 25, 10:37 AM CST
Subject: Applying T-Shirt Texture in Poser5
Totoro3D ( ) posted Sun, 04 January 2004 at 4:47 PM ยท edited Tue, 30 July 2024 at 12:16 PM
Maybe I am really stupid, but even after reading the manual carefully its not working. I am using the Poser 4 T-Shirt and a texture-bmp which was created for the Poser 4 T-Shirt. When I add a "2D Texture Node" and select my shirt.bmp texture as Image source, on the picture below it shows up beautifully, both the back and the top of the shirt. Texture strength is set to "1" but the shirt in my application does not change at all and stays white. Did I miss to select some option?
KarenJ ( ) posted Sun, 04 January 2004 at 5:06 PM
Make sure you pull down the little arrow to the right of the title "Material:" - you are probably applying the texture only to the preview part. Quick tip: Right click anywhere in the material room and click on "Select all", then right click again and click "Apply to all." This will add your texture map to all parts of the figure. TAKE CARE though - it won't work correctly for figures which use different maps for different parts, and will also wipe out any trans maps already applied.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
Totoro3D ( ) posted Sun, 04 January 2004 at 5:22 PM
Thanks for you picture, that was just hwat helped me. Thank you so much helping me :)
