Mon, Dec 2, 11:22 AM CST
Subject: bug in setup room!
gillan ( ) posted Wed, 07 January 2004 at 4:53 PM ยท edited Sat, 30 November 2024 at 12:36 PM
look at that! If i save a figure created in setup room importing a geometry and applying it a skeleton of poser, When i try to reload it the new figure it doesn't have his hip but that of the figure from i have taken the skeleton! i have the SR3 help
stewer ( ) posted Wed, 07 January 2004 at 5:07 PM
Try turning on/off the genitals. Poser handles the genitals toggling by two separate hip geometries, maybe that could be mixed up in your figure.
gillan ( ) posted Wed, 07 January 2004 at 5:13 PM
I have tried, but nothing! I have used skeletons without genital too, like poser 2 [casual guy]
numanoid ( ) posted Wed, 07 January 2004 at 5:49 PM
You definitely have to go to the top bar in Poser, click on the figure tab, and switch the genitals switch. You will always have this problem unless you create your own skeleton from scratch. Search in this forum for Robox, it is a tutorial by Dr Geep that explains how to make your own figure, and there will see how to make your own skeleton. Or you could get the free program called Phi Builder. You can get PhiBuilder from here: http://www.royriggs.com/phibuild.zip This also helps to make skeletons.
sixus1 ( ) posted Wed, 07 January 2004 at 7:53 PM
You could create a copy cr2 of the one that you would like to use for a donor skeleton, then open it in NotePad....do a search for 'genitals' rip out all of the related info. After that there is a geom switch in the hip for the genitals that you will need to rip out also. Rebekah
xantor ( ) posted Wed, 07 January 2004 at 9:08 PM
I usually use the females bones to avoid this problem, You have to adjust them when you apply them but you usually have to adjust them anyway
gillan ( ) posted Thu, 08 January 2004 at 4:54 PM
I have resolved the problem using the female skeletons easy and efficacies thanks really to everybody
