Tue, Oct 8, 1:22 PM CDT
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Oct 06 11:55 pm)
Subject: Help a newbie render Mike2 animation...
ajvelez ( ) posted Sun, 28 December 2003 at 4:18 PM · edited Tue, 08 October 2024 at 11:47 AM
Please Help Me!!! I am trying to make an animation but I have the following problems:
Mike2 has these stupid dots in his eyes and eyebrows and hair. Also his eyelashes look like thin pieces of stretched out skin. It renders fine as a still but when I make the animation the stupid dots look all retarded. I have the same problem with the cyclorama background. There are some additional panels that just show up as all dots (or whatever they are) What do I have to do to get all this stuff to just look normal in the final animation?
Thanks, Adam
pjanak ( ) posted Thu, 08 January 2004 at 4:40 AM
IN POser to export an animation yu need to select Animation/Movie Ouput Settings. Select all the boxes That you want like "cast shadows" etc. Also you should select you render setting(the balls at the bottom). Select Texture Shaded.Then go to Animation/Make Movie. A window will pop up. YOu need to change the Quality setting from "Current display settings" to Current render settings" Don't forget to select "anti alias". PeteJ
ajvelez ( ) posted Sat, 17 January 2004 at 7:01 PM
Thanks a lot!! My animation was all lame, it looked like he had black eyes!!! I will post the animation as a music video "Unchanged" I hope you get to see it!
ajvelez ( ) posted Sat, 28 February 2004 at 1:09 AM
Hello, how are you? I finally have the finished "Unchanged" product up, it's posted at acidplanet.com. Here is the address: http://www.acidplanet.com/artist.asp?songs=210690&T=8247 or you can do a search for Foreordained DMO, Inc. Thank again!! Adam
