Mon, Feb 3, 10:03 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: arrrgh...resizing the production frame...
todd71_63116 ( ) posted Thu, 08 January 2004 at 3:26 PM · edited Mon, 03 February 2025 at 9:39 PM
ok...whats the easiest way to resize the production frame? i click on it..and end up getting everything except it chosen...occasionally i get it selected..help...lol
mmoir ( ) posted Thu, 08 January 2004 at 3:42 PM
I usually select the corner of the production frame to select the frame. There are "black dots" at the corners and centre of the production frame, click on these dots to Scale/move the frame.The Corner dots scale the frame while selecting the center dot in the center of the "white plus" sign allows you to move the frame. Also selecting the Camera in the "sequencer" tray helps in selecting the frame. Regards Mike
Kixum ( ) posted Thu, 08 January 2004 at 6:29 PM
mmoir has it. Selecting the camera usually helps me the most. -Kix
-Kix
sailor_ed ( ) posted Thu, 08 January 2004 at 9:50 PM
If you have "lock aspect ratio" selected in the render room I don't think you can resize it.
ShawnDriscoll ( ) posted Fri, 09 January 2004 at 2:47 AM
I lock mine at 1024 x 768 (72 dpi) and just move the camera instead. I gave up trying to click on those tiny black dots around the view pane years ago. The undo has saved me many times from moving the wrong thing in a scene.
mmoir ( ) posted Fri, 09 January 2004 at 5:50 PM
I just noticed that if the production frame aspect ratio is unlocked and you select the frame and resize it while "shift" is pressed the aspect ratio stays the same . It works as advertised now. Mike
