The transition between the archways and the mirror is too obvious, no? There's that dark line. Yes, I would replace the simple glass globe with something yellowish and semi-opaque. The holders, that is, the rods hanging from the ceiling should be replaced. Centrepiece ... I would put a deformed figure. Not a statue. A live figure with the back turned towards the camera. What's on the floor? Water? Cool pillars!
-- erlik
Erlik, I appreciate the brutal critique, honestly I do! The floor is merely relective, with a celtic texture for bump. I know that there is a seam, but I'm not sure if I even want to get rid of the miror-seam, all things considered it acts as more of an alcove than anything...? But, I agree with something asymmetrical as the centerpiece, good call there, thanks!
No, that's a great point! I knew I had done all of the math correctly, i.e., the pillars and walls were all precisely placed, but I couldn't think of how to rid myself of the Z-axis seam... Good call, Catlin, and thank you very much! Of COURSE I care, silly. Just because I SEEM like an ancient dragon Highlord doesn't mean I am heartless... (grins)
SDL, I like this very much! I don't have a problem with the seam but obviously everyone is different (thank goodness!). It shouldn't be a big deal if you wanted to line them up, it's just a matter of 3D scaling one column and replicating to replace the others. In my mind I think any one stand alone object in the center would look out of place because it will be reflected back countless times and break the illusion of the long running hall. Instead, I would place a long running carpet, like those runners they use in long halls and because it will also be reflected, it'll look like one long running carpet and not break up the illusion. I also think it could do with some brighter lighting. Just my thoughts.
Aye, good point about the endless reflections, Quest, but I had planned on plop-rendering the infinte parts with the center object set to "Hidden". Easy workaround... I'll post the newer version of this one in a bit, need to put some more RAM in before it will render or even stay open at this point...
