Carrara F.A.Q (Last Updated: 2024 Dec 21 9:55 pm)
Attached Link: http://athens.ict.usc.edu/HDRShop/
HDRIshop is one way, but I couldn't determine if it works in OS X without downloading it. From what I read, it's just a matter of converting a "spherized" panorama from 8-bit color to a multiple-precision floating-point color system. The jpeg algorithm is probably the opposite of HDRI. In jpeg, a block of pixels gets 8-bit values from a reference pixel and a fourier transformation, so it's totally unnatural way of describing illumination from a skydome. In HDRI each pixel is independent, and its color and luminance can vary continuously over a much wider range than 256 discrete steps.Attached Link: http://www.acm.uiuc.edu/siggraph/HDRIE/
There is the HDRIE project, the main aim of which is to make the functionality of HDRShop available as open source and cross-platform. However, at present I think you'd have to be proficient at compiling stuff for the Mac in order to use the source files.It's only a matter of time before there's an OS X version. It might be possible to deform a panorama into a box-map, then stitch it into a spherized image, but I don't know how to use Photoshop to convert the integer RGB data into floating point data, unless the typical HDRI file reads out as plain text (unlike jpeg or other image formats). This means that trying to fake it with a tiff image mapped onto a skydome would result in a dark, washed-out render compared to an actual HDRI.
Anytime I see something screech across a room and latch onto someone's neck, and the guy screams and tries to get it off, I have to laugh, because what is that thing?
Bryce can export scenes as 3d panorama's but not in the .hdr format, equaly I can download from the web some wonderfull free panoramic images in JPEG but not HDRI. How can I make these images HDRI for use in Carrara? Is there a converter of some kind available? or am I missing something? I'm using a Mac. Cheers, Grav
