Tue, Feb 4, 12:22 PM CST
Subject: help on animation please
beos53 ( ) posted Sat, 10 January 2004 at 1:57 AM ยท edited Tue, 04 February 2025 at 12:12 PM
When doing an animation and set up several differant poses for a figure, how do you stop the arms of legs from going through the body, while it is going from one pose to another? I checked the manual and the Help and guess or rather hope I am missing something and this can be done rather than manualy fixing each frame. Thank you Steve
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
RealDeal ( ) posted Sat, 10 January 2004 at 2:29 AM
That would be a really great feature. which version of Poser are you using? there are some tricks, not very good ones, specific to P4 & P5; in general, however, you just have to do it manually. A general purpose hint would be to figure out at which frame the overlap is greatest, and adjust that frame alone; sometimes this will fix things as well as providing some interesting ambient motion. Other times it causes your figure to resemble a pretzel. http://www.vrhome.com/traveller/images.htm
PhilC ( ) posted Sat, 10 January 2004 at 5:31 AM
Although its not possible to give a simple one fix solution that will fit every case, the best starting point would be to set key frames at each interim pose (you may have already done this). Now apply a spline break to to eack key frame. An alternative but less satisfactory sollution is to make the whole animation linear.
beos53 ( ) posted Sat, 10 January 2004 at 11:10 AM
Thank you for the information I guess this is going to take awhile to do this animation Thank you again Steve
Lawndart ( ) posted Sat, 10 January 2004 at 12:24 PM
Animation takes a lot of work but don't let that put you off. It is really rewarding. Poser's animation features are more than adequate. Cheers, Joe
pjanak ( ) posted Sun, 11 January 2004 at 12:19 AM
Actually they are very quirky. But if you have the patience it can be done. PeteJ
Lawndart ( ) posted Sun, 11 January 2004 at 2:14 PM
pjanak: Interesting. How do you find them quirky? I may be missing something. Maybe they will see this and fix it in Poser 6.
