Wed, Dec 18, 4:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 18 2:45 pm)
Subject: WIP: Update to make AnimeBoys more... manly.
AlleyKatArt ( ) posted Sun, 11 January 2004 at 6:27 PM · edited Wed, 18 December 2024 at 4:47 PM
Okay, I've noticed, like everyone else, I'm sure... The anime doll doesn't have a penis. She's not supposed to... But my Anime Boys aren't anatomically correct. So, today I was messing around, and, while trying to make BunBun from Sluggy Freelance, I made the start of a penis. And I just kept messing with the mesh until this came out... Now. My questions are, 1, would anyone want this? 2, how can I make it merge better with the hipline in the rendered image? 3, ... how can I lower the resolution some? The penis and testes are higher res than the anime doll!!!
Kreations By Khrys
barriephillips ( ) posted Sun, 11 January 2004 at 6:43 PM
you MADE it ? and you don't know the answers to 2 and 3 ? how did you make it and with what ? Barrie.
Riddokun ( ) posted Sun, 11 January 2004 at 6:45 PM
well i use the free mike2 penis figure found on renderotica (by ulf i thing) and it is quite correct Anyway I had been using penises on mayadolls/anime dolls for longer than before there was any male (because I was trying to make another "kind of character".. hmm see rotica to see what i mean) If you want to design a brand new penis, though i can give you advices or suggestions about what it would need, compared to what other penises do not have and that would be useful, both in regard of maya doll/animedol body, and also thinking about it to be used in a cartoon with line mode... Also how can you make it part of the doll (in a cr2) as "new" actor group ? is it possibler ? also before you make a penis (prop, figure, additional group, maybe using objaction mover, or redistributing it as copyleft licence of maya allow it, for mayadoll at least), you still need to think about one problem: Hide/get rid of vagina morph of mayadoll/anime doll WITHOUT deleting the anus at the same time... try the ulf figure (mike 2 penis) from rotica to see how it looks, and mean while i'll write down a few suggestions. i wish you courage and good work in this. I for sure would be interested would it hav the features i still miss in other genital male morphs...
barriephillips ( ) posted Sun, 11 January 2004 at 6:46 PM
has a thing for hermaphrodites , but they don't have testicles (on the outside) as far as I know. :) So maybe is the answer to #1
Little_Dragon ( ) posted Sun, 11 January 2004 at 6:53 PM
  1. I'm sure that someone will. 3. Many modeling programs have tesselation, LOD, or decimation features to reduce a mesh's polycount. The results aren't usually ideal in terms of polygon-placement, but that might not matter in this case. I can offer to run the mesh through MilkShape's DirectX tools, if you can't do it yourself. I'd ask how you went from BunBun to this, but I'm not sure I want to know.
AlleyKatArt ( ) posted Sun, 11 January 2004 at 7:05 PM
I'm not sure, LD. And Rikkodun, it's gonna be free to my buyers of the Anime Bodies. Barrie, I actually made it in Extreme Morph 3d, the program I do most of my morphing work in. That started out as a simple, high resolution sphere and went on from there to be an oblong shape, which is when it first resembled a penis, because some of the verticies would NOT move, forming the urethra of the penis. And yes, Rikkodun, that is an issue. However, it's also stated plainly that none of the genital morphs work because of that...
Kreations By Khrys
barriephillips ( ) posted Sun, 11 January 2004 at 7:50 PM
Khrys maybe in response to #2 , you need to model some of the hip (at the base) as well as the penis , that way there wont be such a drastic difference in geometries.
barriephillips ( ) posted Sun, 11 January 2004 at 7:52 PM
oops, do I need to tag that as nude if theres already a nude tag in the thread ? .. spose I should... sorry.
AlleyKatArt ( ) posted Sun, 11 January 2004 at 8:15 PM
That's a good suggestion, Barrie. Hmm. Thanks. :)
Kreations By Khrys
Lyrra ( ) posted Mon, 12 January 2004 at 10:12 AM
Yes! we want this .. I've gotten a number of requests for boy-parts for the male morphs I've made for both Sara and the MayaDoll. I also have some smut in mind for the poor las, so these would be excellent, and less bother than fiddling with M3's snap-on tool If you need the mesh fiddled with ahem you can send it over to me for vertice editing .. you do know I'm modeling now, right?
Riddokun ( ) posted Mon, 12 January 2004 at 10:30 AM
hmm khrys, do you remember the "panty" morph on "Maria" for mayadoll by Maya ? you noticed it used it's own texture/materla once put on.. what we most need on a human penis (for mayadoll/anime doll or who care what), is to work hard on the cut/uncut morph, from rest stat to "active" state of the member. I made some dirty tricks wih grouping ool on ulf penis prop if you want to see them. What we need is the "tip" to have a separae material rom the rest of the member, and that once you put an "uncut" kind of morph to make it at rest state or not.. ahem.. erect (sorry but cannot talk about enis withou using some specific words :(), then it would cover partially (from alittle to most of it) the tip wih a secondaery skin, with its own material (or sharing texture and material name with the rest of the "body" of the figure. liek this, you can assign color and highlight settings to the tip, but , unlike most penis props i saw, the uncut versionwon't be same color as what it is supposed to "cover". if you need, i can send you sampel pics of what i did with ulf, but i do not know how o export a setting made with the grouping tool. so only pictures. Also need a few set of full ody morphs that slowly put it from rest and uncut/cut state to mildly "ready" or fully "operationnal" states, with both length and thickness changes at same time. (you know sometimes when you think abvout it, it is funny to see penis props on poser characters that are as big and long at rest than at use...) wish you courage and good work. Oh and YES, i would make my day with only an "anime" version, btu I can tell Lyrra desserve a textured one for mayadude, due the efforts she put in him ! She provided cloth fixe poses too. BTW where are the cloth poses you were talking about in some of your gallery image, khrys ?
AlleyKatArt ( ) posted Mon, 12 January 2004 at 10:34 AM
Lyrra, got an instant messenger? I'll send it on over. Cloth poses, Rikko? I'm afraid I don't remember. I juggle a lot of projects at once, so some things end up slipping my mind from time to time. Also, I don't have Maria. I just have Maya Doll and AnimeDoll.
Kreations By Khrys
Riddokun ( ) posted Mon, 12 January 2004 at 10:47 AM
well, you made a few "showcase" (or nearly like that) gallery pictures in your own gallery here, using your nice male bodies kit (i bought it, it is really good) you also made them weare "casual style" clothes for mayadoll by mayax. Well have a second look at your gallery and the texts below, i am sure it was stated somewhere. You managed to fit a breasted female cloth on your male body,and implied youwould release the poses/mophs for this for us customers (or even as free ? as there are a few other male dolls aroudn here: Lyrra's mayadude.. and DJ han animeboy)
Lyrra ( ) posted Mon, 12 January 2004 at 11:15 AM
Krhys - sorry, I have large and scary firewalls. No file transfers through IMs. You can send it to lyrra@renderosity.com though or lyrra@cyclopsstudio.com Riddokun - and don't forget my male sara 'Simon' in the list of male dolls
Riddokun ( ) posted Mon, 12 January 2004 at 12:28 PM
well, i admit i was lazy and totally missed up the release of sara.. i hav the base free mesh/character, but i did not take the time to watch out for any free col hings made for her, and there was some... but my current internet connection requires me to focus and cannot afford to follow too many characters (i was interested by kaedeko too). So for now, i focus on maya/anim doll mostly ! but given what you managed to do once with mayadoll, i sue will look at your sara 's male my problem is that i don't have the tailor, and any knwoldge or skills regarding modelling or tweaking, and i already have hard time using wardrobe of mayadol, i cannot even /am unable to adapt or make fits all v2 free stuff aroudn here on her or sara, as most people do... i saw popel using p4 clothes, sudi armor v2 or such, on a mayadoll, and i guess on sara too. i would really need some help and informations about how to "use" foreign clothes on a given character they were no meant to. For mayadude and animeboys (khrys' and dj han's ones) we cannot even use the wardrobe for mayadoll (except for your own pose files, thanx). I would like to use even the basic p4male ones !
Lyrra ( ) posted Mon, 12 January 2004 at 12:56 PM
I'll have a look at the male wardrobe (Mike and Dork) and see if I can make anyhting work on MayaDude and Simon. I'm afraid I don't have Khrys's boys or I'd try those too. I'll let people know if I manage anything useful
Torulf ( ) posted Mon, 12 January 2004 at 5:34 PM
That about change clothing fore a new figure was earlier an interesting article on this forum. If the Cloth fits... Conform it! http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1608567 Maybe it work for convering clothing for MD,AD and male figures.
TG
Riddokun ( ) posted Mon, 12 January 2004 at 6:12 PM
Lyrra: for Khrys boy, try DJhan's morphed animeboy instead, they are similar in proportion (i mean as long as clothes are mentionned).. the breasts of DJhan's male figure are a bit flawy, butr aside fromthat it is very good... they have similar proportions, i guess.. (i'll show you a render of both khrys and djhan if you want.. i think djhan morph can be downloaded in an oooooold page of maya bbs...) if you don't find it, lemme know thanx for your help offer.. I really would like to stop let boys naked and make some cool pictures with them. (i have illustrated stories pending... but with only girls it maybe boring)
